Need help on a clone GX200 Please! - Snowblower Forum : Snow Blower Forums
post #1 of 21 Old 08-13-2015, 03:47 PM Thread Starter
Likes (Received): 20
So, 2 years ago I got a chinese 3000 watt generator that had fallen off the back of a pickup (price was right $0). Some motor mounts were broken and the crankcase was cracked so oil leaked out quickly. So I bought a replacement clone 168F motor from fleabay (he is still selling them)
Now I'm finally getting things together. Found out the shaft on the new engine was longer than the old one, so I swapped the old crankshaft into the new motor & put things back together. Everything was going well until I tried to start it, no go!
Tested spark, ok. Plenty of fuel, yes. Tried starting fluid, no go. So I checked the compression & it's showing only 30 lbs. on what should be a new engine. I even went so far as to loosen the valve rockers so the valves would remain closed & shot in some oil(Providing a completely sealed combustion chamber I thought), still only 30 lbs. compression!!!
What am I missing??? I really need some of your collective wisdom here.
Cheers
Paul
GtWtNorth is offline
post #2 of 21 Old 08-13-2015, 04:02 PM
Did you open the throttle when you tested the compression. Also, I am not sure, but if you make the intake valve not open, that aren't you actually blocking the air from getting in there? Wouldn't that result in lower compression?
post #3 of 21 Old 08-13-2015, 04:15 PM
Thanks (Received): 41
Likes (Received): 98
To check compression both valves need to be 'working' and throttle wide open. If you were doing a leakdown test then yes both valves closed.
My guess is the cam timing is off, even with the marks lined up. Those clones change all kinds of stuff every year, even if its the same displacement and year.
Easy enough to get an idea if the cam timing is off. The valve overlap (time when intake is opening and exhaust closeing) should be very close to TDC.
scrappy is online now
post #4 of 21 Old 08-13-2015, 05:27 PM Thread Starter
Yeah, I just realized that with the intake closed it can't take in air to compress! I guess I'll take off the head to check the internal condition & change the head gasket.
Maybe those engines he's selling are "new" seconds?
post #5 of 21 Old 08-13-2015, 05:34 PM
Before you waste a head gasket try what I suggested.
post #6 of 21 Old 08-13-2015, 08:05 PM
Thanks (Received): 143
Likes (Received): 297
Timing?
post #7 of 21 Old 08-14-2015, 07:07 AM
Thanks (Received): 35
Likes (Received): 81
I'm on Scrappy on this one. Make sure the overlap between intake and exhaust is very near tdc on the piston. The timing marks on the new camshaft gear may be wrong.
Maybe put your old camshaft in the new engine.
CarlB is offline
post #8 of 21 Old 08-14-2015, 07:37 AM Thread Starter
Thanks guys, I'll try your suggestions Scrappy. Maybe I can film the action and post that.
Cheers
Paul
post #9 of 21 Old 08-14-2015, 12:43 PM
Likes (Received): 483
+1 with a timing issue.
post #10 of 21 Old 08-14-2015, 01:58 PM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1736
Another thing to check is the compression release. It's handy for pull starting but can be misleading when doing a compression test.
I'm not even saying yours has one just something to check into that might explain the low reading.
Likes 43128 liked this post
