Parts compaibility for Ariens - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 08-31-2015, 08:20 AM Thread Starter
Ariens snowblower Model 924073, Ser. #023991
I am trying to find a parts/model compatibility chart for this machine. I am looking for an impeller specifically, but would take an entire bucket assembly if need be, as a new impeller might be more than the cost of buying a used machine from Craigslist.
One of the blades on the impeller is folded over. I was told that the fix was essentially beating it back into place, as heating it would take the temper out of it. It may be more cosmetic than functional.
Thanks.
jarheaddoc is offline
post #2 of 6 Old 08-31-2015, 09:01 AM
Thanks (Given): 587
Thanks (Received): 769
Likes (Given): 4352
Likes (Received): 1734
14" about $150 p/n #02437651 replaced p/n 02437600
Fits Model
ARIENS 924042 924044 924046 924048 924052 924054 924056 924071 924073 924076 924077 924080 924081 924083 924084 924085 924086 924087 924091 924092 924101 924102 924103 924104 924106 924313 924314 924315 924316 Snow Blower ARIENS 924122 924317 924320 924321 924322 924332 924505 924506 924508 Electric Snow Blower
post #3 of 6 Old 08-31-2015, 09:05 AM
Thanks (Given): 587
Likes (Given): 4352
Post up a picture of it. Might be something you could bend in a vise or with an adjustable wrench instead of beating on it. As long as all the metal is there you really don't have to worry about balance as long as you get it pretty much back to it's original shape/position.
post #4 of 6 Old 08-31-2015, 09:47 AM
Likes (Received): 303
Are you talking just the curled tip bent over backways, or the whole leg that attaches to the main plate of the impeller plate? If it's just the tip and bent really bad over, cut it off and weld it back on, or cut them all off and use stock to bend close to the original curves but longer and weld them on all blades. Pete from the Gilson site describes it here on his website. Scroll down a bit to the impeller repair section. The old Ariens impellers are very thick and will take a weld nicely. The newer styles and lesser machines are pretty thin for home welding. Even if you have to farm out the welding, it's A LOT easier than trying to remove a 25 year old impeller from the shaft. If you do cut and weld the offending tip, scrub up the other side and lay a comparable bead on it if you have a 4 or 6 blade. If you have a 3 blade do them all to approximate a balance.
The Gilson Snowblower Shop Parts Department
post #5 of 6 Old 08-31-2015, 11:46 AM
If you are going through the trouble of welding them you can do them all as an impeller kit. You won't be able to make them touch like rubber, but you can get them pretty close.
post #6 of 6 Old 08-31-2015, 04:39 PM Thread Starter
It's the whole leg. I'm not at all interested in trying to separate the fan from the shaft if I can find an entire front end and swap them out. I really don't feel any excessive vibration.
