Trying to remove scraper bar - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 09-02-2015, 09:50 PM Thread Starter
I have a older 835 Gilson that I am trying to remove the scraper bar. The bolt heads are flat and even with penetrating oil, I cant get the nuts off without turning the bolts while I turn the wrench. Nothing to grab onto as far as the bolt (as they are flat). Any tricks that I might try? Also, should the bar be on the inside or outside of the Auger box? This one has it on the outside, but I have seen other makes and models the other way around.
Art
aggriffin3 is offline
post #2 of 8 Old 09-02-2015, 10:06 PM
Usually they are carriage bolts and heavily rusted on and ground down. I generally cut them off as new ones are cheap and easy to get at any hardware store. Be careful trying to unscrew them as they might be twisting the square holes in the frame and stripping them out.
I bought one of those cheap $15 Harbor Freight angle grinders and a cheap pack of discs for it. Some of the best money I have ever spent.
post #3 of 8 Old 09-02-2015, 10:06 PM
angle grinder with a cutoff disc, 11.99 at hft with 20% coupon plus another 8 bucks or so for the cutoff wheels.
4-1/2 in. 40 Grit Metal Cut-off Wheel 10 Pc
4-1/2 in. 4.3 Amp Angle Grinder
post #4 of 8 Old 09-02-2015, 10:08 PM
Hah, 3 posts all with the same time stamp and all with the same solution.
post #5 of 8 Old 09-02-2015, 10:08 PM
Likes (Received): 483
Smile
For the nuts issue, if you have the room, cut the nut and bolt right in the midle, the nut will split and the bolt would come off (you can use a saw or a cut-off tool). If this does not work, grind the remaining part of the head of the bolt and it will come apart. Or you can drill the center of the head of the bolt to the size of the threaded part of the bolt and it will come apart.
I've seen all scraper bars on the front side of the housing.
post #6 of 8 Old 09-03-2015, 04:03 AM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1741
The grinder :Heavy Duty 4-1/2" Angle Grinder
Or . . . you can use a hacksaw if you have one laying around to cut the nuts in half too.
post #7 of 8 Old 09-04-2015, 07:46 AM
Thanks (Received): 40
Likes (Received): 149
Your 835 circa 1967-69 will be a tough customer.
If you want to try to salvage the originals here is what I do:
1) Spray with Kroil, PB Blaster etc.
2) Use a disc grinder to remove the protruding bolt, this will eliminate the buggered up threads.
3) More penetrating lubricant
4) Clamp the bolt with a pair of special pliers
5) Remove with a 6 point socket on a ratchet or impact wrench
6) If that does not do the trick then blow it away with a grinder, cold chisel or air hammer.
7) Some will be held firmly but will snap rather than unscrew.
8) Heat should help too
Replacements found here.
Pete
Spectrum is offline
Likes Kiss4aFrog, db130, Grunt liked this post
post #8 of 8 Old 09-04-2015, 08:16 PM
Likes (Received): 20
Just one more reason to own a smoke wrench. Or make friend with someone who owns one...
sidegrinder is offline
