Grinding exhaust valve stem - Snowblower Forum : Snow Blower Forums
post #1 of 2 Old 09-14-2015, 11:41 AM Thread Starter
Thanks (Given): 34
Likes (Given): 58
Likes (Received): 33
I'm slowly getting what I need to finally take care of the alleged exhaust valve issue on my HMSK-80. I still haven't even pulled the valve cover to check clearance but hopefully will have time by October.
The question I have is I recall someone on the forum setting up a jig made out of wood to hold the valve and then he used a drill press to grind some off of the stem.
What bit would you use for this? I'm thinking something like McMaster-Carr 4919A531 or 4919A561
http://www.mcmaster.com/
I've got a decent drill press (1930s Canedy-Otto 16") and a sliding vise is finally coming for it today so I'll actually be able to use it.
I know some guys just go over it with a file but I like the idea of using the drill press.
If the clearance is fine when I check it, my alternate plan is to put a Honda GX-200 I have on the Ariens. I'm hoping it won't come to that though.
1999 Ariens 924108 824SLE.
1933 GE Monitor Top refrigerator restoration video
ChrisJ is offline
post #2 of 2 Old 09-15-2015, 12:30 PM
Thanks (Given): 63
Thanks (Received): 70
Likes (Given): 277
Likes (Received): 173
Chris: I'm just a beginner, but will pass on what I did. I ground a valve earlier this year, worked pretty good. For the jig, I clamped 2 6" lengths of 1x2 together, and drilled a whole between them, slightly smaller than the valve stem. I then "clamped the valve in between the 2 pieces of wood with some screws. I was able to use the edges of the 1x2s to rest against the miter gauge on a disc sander table, and gently brought the valve stem end to the sander. It worked really well, the new ground edge was square to the stem length. (though I must admit, I'm not sure if the ground edge is supposed to have any taper to it). I just went real slow, made sure the stem never heated up too much, ground a little, install and measure, ground some more, etc.
Paul
paulm12 is online now
