Chute finish (smooth, tough and slick) - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 10-03-2015, 01:57 PM Thread Starter
Thanks (Received): 147
Likes (Given): 215
Likes (Received): 305
I'm trying to squeeze some time into painting a few parts before it gets cold.
I worked on my chute yesterday. I didn't take any photos of the inside while it was bare, but it had more time invested than I care to admit smoothing the inside. Wire wheel, flapper disk, blast cabinet. the works. It still had some texture. Bear in mind this machine spent many years in service with a lot of gravel going thru it. I had to do a lot of work to the impeller housing from all this gravel damage.
When it was bare metal yesterday, after hours of grinding and sanding the inside I thought I was going to be able to remove the remaining texture with some simple wet sanding of the primer. Today I realized all these gravel marks are way deeper than it looked when it was bare metal. We all understand the advantages of a smooth slick chute.
I don't really think have any question or am seeking any advice, I'm just realizing the dilemma. I could spend a bunch of time filling and sanding this surface, but the filler may contribute to an early failure of the finish as more abrading takes place in the future. If you cant stop it from happening, how much effort is it worth?
Example photo of outside since I don't have one of the inside which had much more time and effort involved.
What I had this morning after letting the primer cure overnight.
My dilemma.
dbert is online now
post #2 of 10 Old 10-03-2015, 02:07 PM
Thanks (Given): 33
Thanks (Received): 37
Likes (Given): 64
Likes (Received): 87
That looks to be a good surface texture texture for applying a two-part epoxy and a sheet of Teflon. I've never done it but I imagine it's a pretty smooth, slick surface to get the wet stuff from plugging up the chute.
2015 Ariens Deluxe 28+ 921037, 414cc LCT (now son's)
2014 Ariens Platinum 30 921029, 414cc LCT (mine forever)
PixMan is offline
post #3 of 10 Old 10-03-2015, 02:27 PM Thread Starter
Likes (Given): 215
I would LOVE to install a teflon liner. I've given it a lot of thought. I've got a little experience with thermo forming some plastic. that was stuff that would fit in a kitchen oven however.
What I believe would be the big challenge here would be the compound curve. Getting it to bend inward along one plane would be easy, but this needs to bend along two.
dbert is online now
post #4 of 10 Old 10-03-2015, 02:30 PM Thread Starter
Likes (Given): 215
Attn all snow blower manufacturers. Make something like this that fits your chutes and a simple (couple of clips or something) way to attach them.
Plastic liners.
If I had to replace it every year, no biggie.
dbert is online now
Likes 1894 liked this post
post #5 of 10 Old 10-03-2015, 05:46 PM
Thanks (Given): 33
Likes (Given): 64
You should be able to find 1/16" thick sheets of Teflon, so compound curves aren't an issue.
PixMan is offline
post #6 of 10 Old 10-03-2015, 06:37 PM
they wouldnt make a liner even if they could make it it just gives you another reason not to buy a new blower, sad to say but true nowadays
post #7 of 10 Old 10-03-2015, 08:38 PM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
If you're feeling adventurous (and rich), McMaster-Carr sells adhesive-backed PTFE (Teflon equivalent) film: McMaster-Carr
ELaw is offline
post #8 of 10 Old 10-04-2015, 04:18 PM
Thanks (Received): 40
Likes (Received): 149
If they make it a consumable needing emplacement every year or 2 it becomes an annuity.
Spectrum is offline
Likes nwcove liked this post
post #9 of 10 Old 10-04-2015, 06:32 PM
Thanks (Received): 33
Likes (Received): 54
I've used UHMW in the past. Pop it in the oven @250 or 275 and it's pretty easy to form
mobiledynamics is offline
post #10 of 10 Old 10-05-2015, 05:02 PM
Your answer is POR-15. Did this to a taller chute I picked up cheap and the inside is as smooth as a baby's bottom. Do just the inside and let it self-level and it will fill in all of those holes.
threeputtpar is offline
