Oil leaking out of governor shaft Tuecumseh HM80 - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 10-05-2015, 10:50 AM Thread Starter
GAR
GAR's Avatar
Thanks (Given): 68
Thanks (Received): 18
Likes (Given): 248
Likes (Received): 150
I need advice, is there a replaceable O ring on the governor shaft or if the problem could be a clogged breather causing the internal engine pressure to blow oil out there or could the bushing in the governor be worn out and I need to replace the hole front of engine to fix this?.......I really don't know so any advice would help....Thanks, Greg
GAR is offline
post #2 of 3 Old 10-05-2015, 11:39 AM Thread Starter
GAR
GAR's Avatar
Thanks (Given): 68
Likes (Given): 248
Omg.....Things are never this easy....LOL. I pulled the engine breather cap and the tube was completely pluged. I replaced the tube and put the breather cap and new tube back on engine, restarted it and NO oil leak. So with the engine breather clogged I would guess the engine presure was high and it caused the oil to seep out the governor hole....
GAR is offline
post #3 of 3 Old 10-05-2015, 01:25 PM
Thanks (Given): 588
Thanks (Received): 769
Likes (Given): 4353
Likes (Received): 1736
Life is good
