Ariens Deluxe 28 SHO 921044 Squeaky Chute Control - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 10-08-2015, 11:01 AM Thread Starter
Thanks (Given): 44
Thanks (Received): 14
Likes (Given): 235
Likes (Received): 47
Hey guys/gals just got my new Deluxe delivered from the dealer and it looks and feels amazing. One question though, i've noticed some others have had this issue before but when turning the chute left and right it sounds like Chewbacca yelling at me lol. The noise comes from underneath the worm gear when it looks like there is a few circular bushings. I sprayed a little white lithium grease in there and worked the chute back and forth and it went away but not even a day later(not using it at all obviously) and the noise is back. I contacted Ariens who said it sounds like the bushing might be worn or installed incorrectly and to call the dealer. Now before i go calling the dealer and trying to get them to come pick it up on their dime is there a suggestion for me to try, i'm pretty mechanically inclined and can do a good amount of work myself. Thanks!
2016 Ariens Deluxe 28 SHO AX306cc (921044) | Drift Cutters | Front Weight Kit | Handwarmers
1965 Ariens 10ML60D with 1970 10,000 Series Sno-Thro Attachment 10995 | Tecumseh H70-130216G (7HP)
2016 Ariens Razor SP Mower AC159cc (911175)
2016 Predator 8750 Peak/7000 Running Watt Generator 13HP 420cc (69671)
Elt31987 is offline
post #2 of 4 Old 10-08-2015, 03:15 PM
I had the same issue. Its a loud high pitched wine when turning the chute in any direction. It's a pretty simple fix.
The bolt is located underneath this. No need to take the cover off as seen in the picture I am just giving you an idea of the bolt. Its circled in red. Loosen this bolt up until the squeeking goes away.
Vengenz is offline
post #3 of 4 Old 10-08-2015, 03:27 PM Thread Starter
Thanks (Given): 44
Likes (Given): 235
Appreciated. Ill do it tonight when i get in and let you guys know
Elt31987 is offline
post #4 of 4 Old 10-08-2015, 07:28 PM
liftoff1967's Avatar
Thanks (Given): 36
Thanks (Received): 45
Likes (Given): 65
Likes (Received): 94
+1 for the fix. There is a fine line between getting it loose so it does not squeak, but still keeping some tension on it so the chute stays in place when pitching wet heavy snow. I would keep it as is and try it this winter. With the motor running at high rpm, my guess is you will not hear the squeak.
liftoff1967 is offline
