Ariens 10ML60D drive system - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 10-09-2015, 05:44 PM Thread Starter
Thanks (Received): 11
Likes (Given): 9
Likes (Received): 30
I have one of the above mentioned guys. I was giving it some love and decided I would pick a scab and remove the right side wheel drive hub, just to check it out. I have never had these off before; so I know nothing about them. I wanted to learn. I have found that there was a large friction ring with a tab in the middle of it, that has broken in three pieces...the two ring halves and the little tab that was in the middle. Parts Tree lists the model; but when you look at the drive parts, they don't show anything like it. The rest of the inside of this mechanism consists of a double acting pawl device that I suspect works as a ratchet. This pawl thing engages in internal teeth of a drum that the wheel attaches to.
Where can I find the right parts breakdown for this? Where can I find parts? And how important is that thing? It seems like it was working okay last winter.....
bwright1818 is offline
post #2 of 7 Old 10-09-2015, 05:54 PM
you have the parts diagram open for the regular 10ml60 (non differential version)
post #3 of 7 Old 10-09-2015, 05:58 PM Thread Starter
Likes (Given): 9
Wow, thank you for the fast reply! I went back and looked at the diagram again. It's there, up in the left hand corner by itself. Of course, it's NLA....
post #4 of 7 Old 10-09-2015, 06:32 PM
Likes (Received): 20
I have a small box of these ratchet drive hub parts somewhere. I'll try to dig it out and see if there is a friction cup. It doesn't ring a bell though...
sidegrinder is offline
post #5 of 7 Old 10-09-2015, 07:48 PM
Thanks (Received): 194
Likes (Received): 816
I have friction springs available, but not cheap. PM if interested.
Jackmels is online now
post #6 of 7 Old 10-10-2015, 05:47 AM Thread Starter
Likes (Given): 9
Thanks....I did send you a PM.
Bill
post #7 of 7 Old 10-10-2015, 02:17 PM
Oops, I don't know where I got cup from, must have been a senior moment.
