i need a coil help with part # please - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 10-10-2015, 11:54 AM Thread Starter
model is 38080
ser is 6002298
toro 824
what would the coil part # be
wantboost is offline
post #2 of 11 Old 10-10-2015, 11:58 AM
Likes (Received): 42
Hi wantboost
Are you sure the coil is n/g? Not usually the case. How did you test it? MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #3 of 11 Old 10-10-2015, 12:00 PM Thread Starter
i cleaned the wheel and disconnected the main safety/grounding connector and still no spark
post #4 of 11 Old 10-10-2015, 12:07 PM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
Instead of asking for a coil for a snowblower you might want to post the numbers off the engine, model/serial/family as those are the numbers that matter.
You should also try to identify the machine a little better. Is it a Toro ??
post #5 of 11 Old 10-10-2015, 12:09 PM
Did you have a spark and lose it...or never had one? Make sure key is "on" and throttle is off the "stop" position, too. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
post #6 of 11 Old 10-10-2015, 12:33 PM Thread Starter
model is 38080
ser is 6002298.
toro 824
i cannot find the stamp on the motor. Ive obtained this from a friend . I cleaned flywheel and disconnected main safety/ground hardness .
yes key is on and throttle is off of stop . i doubt this would matter since i have harness disconnected
post #7 of 11 Old 10-10-2015, 01:00 PM
The harness is for the safety switch...it will kill the engine if the right grip is released when the drive is engaged. The stop switch is separate as is the key. To bypass all, disconnect the engine coil lead from everything. If you have done that, be sure that the wire is not shorting against the engine anywhere between the stop/safety connection and the coil...a frayed wire for example. Did you check the air gap between flywheel and coil? MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
post #8 of 11 Old 10-10-2015, 10:09 PM
Your engine is a 8 hp Tecumseh model HM80-155291K.
The coil part number is 35135B and retails for around $50.
Snow Knight is offline
post #9 of 11 Old 10-10-2015, 10:25 PM
Thanks (Given): 590
Likes (Given): 4371
$15 on ebay, shipped.
post #10 of 11 Old 10-11-2015, 02:05 PM
Well, that's an aftermarket part, so, yeah, $15 to $20 for an aftermarket coil, $50 for the genuine Tecumseh.
