DIY head surfacing after gasket failure - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 14 Old 01-02-2017, 08:57 PM
Thanks (Given): 78
Thanks (Received): 161
Likes (Given): 401
Likes (Received): 641
Originally Posted by toroused View Post
For those who have done something like this before, about how much time did it take to wet sand the head in the article - 20 minutes, 30 minutes, an hour? Even more?
Also, as far as the directions stating to turn this thing periodically during the process, what is the best method - turning from say 6:00 to 9:00 then to 12:00 etc. in some type of specific, circular sequence?
ive done this to numerous ob motor heads, and there is no " how much time". a slightly warped head can be done in less than a half hour. a really twisted one may take close to 2 hrs. i do figure 8's and rotate the head 180 now and then...all depends on what you see on the mating surface.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #12 of 14 Old 01-02-2017, 09:38 PM Thread Starter
Thanks (Given): 572
Thanks (Received): 743
Likes (Given): 4223
Likes (Received): 1641
The amount of time it takes would depend on how badly it's warped. You can always take a magic marker and color the surface before you start sanding to make sure you have it flat. Usually the sanding itself will make the metal look bright so it's pretty easy to see. I'd rotate it 90 degrees each time.
post #13 of 14 Old 09-04-2017, 09:35 PM
Guest
Thanks (Given): 20
Thanks (Received): 54
Likes (Given): 40
Likes (Received): 94
that's how i mark mine. blue or black magic marker unless your lucky and have some machinist blue laying around to mark the surface
i also use lapping compound in place of sand paper using 3 grades course med fine to get a better surface,
10953 is offline
post #14 of 14 Old 09-05-2018, 11:24 AM
aveteam's Avatar
Thanks (Given): 11
Likes (Given): 18
Likes (Received): 8
I'll second the figure 8 pattern. I do mechanical assembly and whenever we have to lap a part that is the recommended way.
Sent from my LG-M322 using Tapatalk
"Where's that confounded bridge"? - Robert Plant, "The Crunge"
aveteam is offline
