Need help identifying a craftsman snowblower part - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 10-11-2015, 07:13 PM Thread Starter
I picked up a craftsman snowblower for short money this summer. Had a couple of issues when I picked it up, otherwise in really good shape.
The problem I need help with is that the auger belt falls off when not engaged. I think there's a piece of sheet metal or bracket that holds the belt on the pulley when disengaged, and the previous owner somehow either broke or lost this part. He fashioned some kind of sheet metal bracket which obviously doesn't work.
Can you help me identify the part I need? It's an 8.5 hp tecumseh motor in a canadian craftsman snowblower. I've attached a couple of pictures for reference. Frankly I'm not even sure if he put the right belt on. ANybody know the size?
Thanks a bunch
killerfomula is offline
post #2 of 7 Old 10-11-2015, 07:35 PM
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3335
Likes (Received): 679
killerfomula. The part missing is called a belt keeper and looks like the picture below. You could buy them using your engine numbers at most any small engine shop or online. You could also make your own out of any round stock that's measures around 1/8" (3mm?).
Sorry about the missing photo.
post #3 of 7 Old 10-11-2015, 10:07 PM
Likes (Given): 215
Likes (Received): 304
I'm not seeing a picture in Grunts post. Here is a photo of mine. Completely different machine, but you get the idea.
note: Ignore the prybar in these photos. I was trying to show another member with the exact same machine just how much slack I had in my belt as his would not stop driving the auger when released and he wondered if he needed a longer belt.
dbert is online now
Likes Grunt liked this post
post #4 of 7 Old 10-11-2015, 10:33 PM
A lot of older Craftsman snow throwers were made by Murray & MTD, but this one kind of looks like it was made by Noma (which was bought out by Murray).
Grunt is right. It's missing a belt keeper. Sometimes it's something so small that will ruin everything. I would try something that looks like this:
Something like this is Murray part number 3949MA and should work. It can be purchased from any Briggs & Stratton dealer for around 5 bucks or less.
Snow Knight is offline
post #5 of 7 Old 10-12-2015, 07:26 AM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1739
Welcome to the forum
You might also want to check the belt to make sure it's the right one for your machine and adjust the tensioner if you haven't yet.
That keeper is important but so is keeping the correct amount of slack without it becoming excessive.
post #6 of 7 Old 10-18-2015, 02:14 PM
Thanks (Received): 112
Likes (Received): 298
Check with Sears Canada and see if you can get a manual for that machine. They found one for me on a 24 year old unit with an 8HP Tecumseh engine. That belt seems to have a lot of slack, Im guessing it was changed with whatever was around, and is not the right one for that unit, or it is so stretched that its way out of spec. The manual will have part numbers for both the belts, and the keeper.
Last edited by Kiss4aFrog; 10-18-2015 at 02:36 PM. Reason: Removed duplicate photos
skutflut is offline
post #7 of 7 Old 10-18-2015, 06:55 PM
Likes (Received): 345
I've made a bunch of belt keepers over the years. You need a piece of 1/4" steel rod, some tools and a hot torch and a bolt to bend it around. I made up a little jig I can clamp down to bend it around and a mapp torch is hot enough to bend the rod easily.
I've attached some pictures, hopefully it will make sense.
ID:	59346   Click image for larger version
ID:	59354   Click image for larger version
ID:	59362   Click image for larger version
HCBPH is offline
