MTD antique snow blower? - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 10-13-2015, 12:51 PM Thread Starter
Likes (Received): 58
Talking MTD antique snow blower?
About to install and new engine on my MTD road side find 5/24 snow blower. Figured since the old trashed engine is off I would install a set of new belts. On the ID tag it is 310 550 000\ 1069B, I think the model number is 310 550 000 I also think it was MFG 10 1969.
Any way can some one help me out on belt sizes? All I can find is a 310 550 0089 and all the belts are a part number with hefty price tag. I did save the old belts so if push comes to shove I can go to a belt dealer maybe.
Al
alleyyooper is offline
post #2 of 7 Old 10-13-2015, 01:01 PM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1739
Are you replacing the engine with the same thing ?? Same distance from base to center of crankshaft ?? Same diameter pulley ??
post #3 of 7 Old 10-13-2015, 01:27 PM
im assuming a predator is going on
post #4 of 7 Old 10-14-2015, 05:26 AM Thread Starter
Talking
Yes the remains of the old 5hp tec. came off yesterday, the new 212 Predator is all prepped to go back on.
OH NO!!!!!
I never thought to measure the shaft height to see if they are the same.
Cotton picken ELDER MOMENTS come at the darnest times.
Al
post #5 of 7 Old 10-14-2015, 07:55 AM
usually the shaft height on the predator and honda clones is a bit lower then tecumseh and briggs engines
post #6 of 7 Old 10-14-2015, 11:02 AM
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3335
Likes (Received): 679
Here is a link to the MTD belt part numbers and it shows the belt size next to them.
Example: MTD part number 00023887 is a 1/2"x48" or typically, 4L480
MTD Belt size, length, width for MTD belts by part number.
post #7 of 7 Old 10-14-2015, 02:20 PM Thread Starter
Talking
Set the old tec. engine beside the new Predator and laid a level on the shafts. Maybe 1/8 inch difference or could have been a bit of crud under the Tec engine.
Any way got the belts out and took them to TSC and bought two new ones for about $25.00 for the pair. Put them on the one for the wheel drive is a little bit wider but should work just fine.
Got the engine installed and a one pull start, auger and impeller runs fine.Wheels drive works too but I still have two flat tires and am trying to decide if I want two new ones or just tubes but the old tires are weather checked bad.
Al
