How analyse a coil - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 10-15-2015, 06:31 PM Thread Starter
Likes (Received): 82
How analyse a coil
If Coby is around I would be interested to know how can one tell if a charging coil outputs dirty voltage or acceptable current for Led lights.
My new engine can output 60 watts. If I connect it to a 12 volt battery which would then power the hand warmers, charging the battery and the Led which I think consumes 15 watts. Any comments appreciated.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #2 of 5 Old 10-15-2015, 07:05 PM
Thanks (Given): 592
Thanks (Received): 773
Likes (Given): 4377
Likes (Received): 1744
BEFORE you connect a battery you need to make sure it's producing DC and that it's regulated so it doesn't damage the battery.
Most charging systems produce unregulated AC as that is what the basic components produce and changing it to DC costs $$ as you need to add a rectifier of some sort and if you're running a battery you need a regulator to keep the voltage at a proper level ( <15 volts ).
Some of the newer LEDs come with an internal rectifier so they are plug and play as is.
What exactly is your "new engine" ??
post #3 of 5 Old 10-15-2015, 07:15 PM
Likes (Received): 483
This is his new engine
post #4 of 5 Old 10-15-2015, 07:32 PM Thread Starter
Thks Hsblowerfan , I just tested the output of the coil and it shows DC Volts at 19.1 volts at full speed (3725 rpm)
A 12 volt battery should handle this or not. Btw the battery is a gel type and good to start small engines and such.
Normex is offline
post #5 of 5 Old 10-15-2015, 07:56 PM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
I saw the title of this thread and thought "Well, it's probably best to start by asking about its childhood".
But more to the point... here's what you really need to do. Get a good, fully charged battery. Hook it to the coil, start the engine and run it at normal speed, and measure the voltage at the battery terminals.
If it's about 14.5 volts or lower you should be okay. 14.5-15.5 is okay too but you'll get reduced battery life. Above 15.5 volts will shorten the battery life so much you probably should think about installing a regulator.
Again the above numbers are only valid *with a fully charged battery*. If the voltage is rising as you measure it, either wait until it levels off, or disconnect the battery and charge it with a charger.
ELaw is offline
Thanks Normex thanked for this post
Likes dbert liked this post
