Impeller shaft play ST824 - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 10-16-2015, 10:46 AM Thread Starter
Hi Guys,
On my 924050 with the aluminum gearcase how much play should there be in the impeller shaft fore and aft. I'm just wondering if the thrust bearing is wearing out. I have about 1/2".
Thanks.
AandPDan is offline
post #2 of 6 Old 10-16-2015, 10:48 AM
Really shouldn't have any. There is a collar on the bushings that prevent that. Now might be a good time to open up the gearbox anyway as the grease in the aluminum ones can harden and dry out over time. When I opened mine up I wedged a washer between the bushing and the gearcase to push it tighter against the impeller shaft. In my case, the old grease still looked like new, but I replaced it anyway as I had it open.
post #3 of 6 Old 10-16-2015, 10:51 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
I agree! A few thousandths or tens of thousandths okay, 1/2" not so much.
ELaw is offline
post #4 of 6 Old 10-16-2015, 02:51 PM Thread Starter
Thanks guys. I figured as much.
Looks like I have a project for the weekend then.
AandPDan is offline
post #5 of 6 Old 10-16-2015, 04:57 PM Thread Starter
Pulled most of it apart. The bushings in the gearbox are gone but the gears/shaft look good. Definitely found the source of all the play.
If I could just get the impeller off now...
ID:	59202   Click image for larger version
AandPDan is offline
post #6 of 6 Old 10-21-2015, 07:35 PM
Thanks (Received): 112
Likes (Received): 298
If I could just get the impeller off now...[/QUOTE]
Don't force it, use a bigger hammer!
skutflut is offline
