Wire sizing - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 10-21-2015, 01:04 PM Thread Starter
Normex's Avatar
Likes (Received): 82
Wire sizing
My new engine has AC voltage supply with 18 gauge wiring, would the wire size be sufficient to supply a 20 watt hand warmer?
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #2 of 8 Old 10-21-2015, 05:53 PM Thread Starter
Normex's Avatar
Can anyone please elaborate?
Normex is offline
post #3 of 8 Old 10-21-2015, 06:12 PM
Likes (Received): 12
Depends on the voltage. If the snow blower is putting out 12 volts, 20 watts is only about 1.7 amps. 5 amps and above and you would want 16 gauge. Is there anything else drawing from that wiring like a light? Also, do you know how much output your machine has electrically?
JTD771 is offline
Thanks Normex thanked for this post
Likes Grunt liked this post
post #4 of 8 Old 10-21-2015, 06:22 PM
Thanks (Received): 173
Likes (Given): 414
Likes (Received): 663
i admittedly know very little about the voodoo of electricity, but hope this helps......Wire gauge calculator : Denning Electronics
post #5 of 8 Old 10-21-2015, 06:24 PM
Grunt's Avatar
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3332
Likes (Received): 679
Hello Norm, glad to see your back and hopefully doing well. From a bit of browsing, it looks like an 18 ga wire will handle 6 amps of load. 20 watt hand warmers divided by 12 volts = 1.6 amp draw, so the 18 ga is large enough to handle the load.
The formula is Amps = Watts divided by volts.
Uh Oh, my slow finger was to late typing, JTD beat me to the draw.
post #6 of 8 Old 10-21-2015, 06:37 PM Thread Starter
Normex's Avatar
Thanks for responding JTD and the AC side of the supply is only used for the hand warmers. The charging coil is supposed to output 5 to 7 amps.
Normex is offline
post #7 of 8 Old 10-21-2015, 06:44 PM Thread Starter
Normex's Avatar
[QUOTE=Grunt;715642]Hello Norm, glad to see your back and hopefully doing well. From a bit of browsing, it looks like an 18 ga wire will handle 6 amps of load. 20 watt hand warmers divided by 12 volts = 1.6 amp draw, so the 18 ga is large enough to handle the load.
Grunt thanks for the exact information I needed.
Normex is offline
post #8 of 8 Old 10-28-2015, 09:43 AM
Thanks (Received): 112
Likes (Received): 298
Electricity is a science! Rechargable batteries and chargers are Voodoo
skutflut is offline
