What lube use for the chain? - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 10-26-2015, 12:02 PM Thread Starter
Thanks (Given): 7
What do you use to lubricate the chain? I read that I have to put oil.
Here I use Jig-a-loo White lithium grease lubricant water-repellent Super Grease, do you think it is ok?
Thank you
JF
ID:	60497   Click image for larger version
post #2 of 12 Old 10-26-2015, 12:26 PM
Likes (Received): 82
The grease should be ok as long as it is not too thick being easily spread with the tip of your finger but remember avoid putting some on the friction disc and the friction wheel at all cost.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #3 of 12 Old 10-26-2015, 12:32 PM
Thanks (Given): 588
Thanks (Received): 769
Likes (Given): 4353
Likes (Received): 1736
What machine ?? Where is the chain located ??
On my three stage where a chain is out on the augers I submerge it in oil during the fall check over and use chain lube spray a couple times during the winter.
It was the first thing I replaced when I bought it as the chain was rusted solid and wouldn't flex at all from lack of maintenance.
On drive chains inside the transmission housing I usually just oil them. I feel the oil penetrates better than a spray.
post #4 of 12 Old 10-26-2015, 02:57 PM
Thanks (Given): 173
Likes (Given): 453
Likes (Received): 1029
Motorcycle chain oil would probably do a good job. It's pretty much all weather.
post #5 of 12 Old 10-26-2015, 04:03 PM
Thanks (Received): 41
Likes (Received): 98
Plus 1 for motorcycle chain lube.
It's water proof and sticky so it won't fling all over the place. Plus it comes in spray can.
scrappy is online now
post #6 of 12 Old 10-26-2015, 04:26 PM
Thanks (Given): 10
Thanks (Received): 19
Likes (Given): 9
Likes (Received): 59
I was told the Silkolene is the best it is motorcycle chain lube.
I use it on my snowbirds chain and on some of the other moving parts that have no grease fitting to grease..
There are other blends, I bought this one, ( I must add not from this site, site just for reference)
https://www.silkolenestore.com/more.asp?ProdID=183
I hate shoveling SNOW!
22" Dual Stage
"Classic" 1963 S-226 Snowbird
22" Dual Stage
Big Ed is offline
Thanks [email protected] thanked for this post
post #7 of 12 Old 10-29-2015, 03:52 PM
Likes (Given): 82
Likes (Received): 35
motor oil
Bob E is offline
post #8 of 12 Old 10-29-2015, 06:14 PM
Plus 2 on motorcycle chain lube.Used it for years on all sorts of chain driven equipment and my motorcycles.
pdesjr is offline
post #9 of 12 Old 10-29-2015, 06:48 PM
Likes (Given): 18
Likes (Received): 8
A sincere "Thanks!" to all, as it's threads like these make me happy I'm a forum member as it provides insights into a question that I have had bouncing around in my head.
PolarNorth is offline
post #10 of 12 Old 10-30-2015, 12:52 PM Thread Starter
Thanks (Given): 7
Thank you very much everybody for yours answers! I will use motorcycle lube in future.
Thank you
JF
