Auger Support - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 10-29-2015, 11:35 AM Thread Starter
Thanks (Received): 33
Likes (Received): 54
Auger Support
I don't deal with these often so I'll poke your brains.
If I simply remove one side of the bearing cup on the end of the auger that is mated to the side of the bucket, how much deflection/movement of the auger should I expect. A hairs breath drop ?
I plan to install PPF on the exterior of the bucket.
What that entails though is to remove the screws for the bearing cup on the bucket and then reinstall once I have the film laid on
To make a long story short, as I can't recall all the details, but I did something similar on my brand new Honda years ago, and I ended up doing more work that I thought post buttoning it up. I can't recall the details but I do recall having to go a buy a new bearing for whatever reason that it may be...
mobiledynamics is offline
post #2 of 6 Old 10-30-2015, 06:57 AM
Likes (Received): 1379
if you are taking one side at a time. there should be a little movement in there. but not all donuts breaking loose. for the whole world to see.
post #3 of 6 Old 10-30-2015, 07:31 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
That's going to depend on what kind of snowblower you have, and to a degree on how "old and tired" it is. But in most cases I'd expect more than a hair's breadth of drop.
On a snowblower with new or like-new bushings and bearings, and the auger gearbox supported by a bracket, you might get 0.010" of drop when you remove one bearing/bushing. On a machine with worn bushings/bearings, and the auger gearbox not supported by a bracket, I wouldn't be surprised to see 1/4" or more of drop.
ELaw is offline
post #4 of 6 Old 10-30-2015, 10:10 AM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1738
What snow blower are you working on ?? Most only have a bushing that the shaft rides on.
post #5 of 6 Old 10-30-2015, 08:38 PM Thread Starter
Husq. 300 Series.
I'm not sure in what position I'll have the snowblower....when I install the PPF.
I'm simply planning to remove the screws holding the bearing cup, install the film and then put / secure the bearing cup back on. Then proceed onto the other side of the bucket, once I have 1 side done
post #6 of 6 Old 10-31-2015, 06:58 AM
Thanks (Received): 35
Likes (Received): 81
you shouldn't get much deflection with only one side removed.
CarlB is offline
