Muffler glowing red - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 11-12-2015, 12:17 PM Thread Starter
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 268
Muffler glowing red
Hi Gang-
Need some advice from the experts. Tecumseh 8 HP engine early 90s vintage. (not mine) when I was doing some fine tuning of the carb earlier this year, I could see the muffler start to glow red, but with a few changes to the carb adjustment it would go away. I ended up rebuilding the carb recently and the machine runs much better, but have not yet ran it at night to see if it gets the muffler hot enough to start glowing.
Thoughts on why it would glow in the first place? Just the mixture not being set correctly? The muffler seems to be in good shape otherwise and the machine is stored inside a shed and has been since they purchased it. Gasoline is always fresh and the fuel shut off is always turned off after done with the snow blowing, allowing the engine to die once it's used up all the fuel in the line and carb.
GoBlowSnow is offline
post #2 of 14 Old 11-12-2015, 12:37 PM
Likes (Received): 82
Originally Posted by GoBlowSnow View Post
Hi Gang-
When the muffler glows it means it is running lean but a little glowing in the dark is no cause for alarm. So if you can adjust it so it doesn't glow just don't go to the rich side too much where you will gum up the spark plug hence having hard starts.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
Likes Grunt liked this post
post #3 of 14 Old 11-12-2015, 01:06 PM
Thanks (Given): 79
Thanks (Received): 83
Likes (Given): 329
Likes (Received): 362
If the machine has been in a shed for any amount of time it might be worth verifying that there isn't mouse nest under the flywheel shroud.
A nest would restrict cooling air and cause the engine to run hot.
1989 John Deere 1032
tdipaul is offline
post #4 of 14 Old 11-12-2015, 01:07 PM
Thanks (Received): 17
Likes (Received): 62
Take the muffler off and check it. Mine did that and it had rusted internally and had a loose part that you could hear when shaken. You may also have a bad gasket.
CO Snow is offline
post #5 of 14 Old 11-12-2015, 01:56 PM
Thanks (Given): 173
Likes (Given): 453
Likes (Received): 1029
+1 on this
post #6 of 14 Old 11-12-2015, 02:40 PM
Likes (Received): 1378
Are the revs per minute within specs??????????????????????
post #7 of 14 Old 11-12-2015, 05:58 PM
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3334
Likes (Received): 679
Don't forget, these are air cooled motors with extra shielding designed to be run in colder temperatures. Tuning a snow engine when it is 80 or 90 degrees out will have some effect on the engine and I agree with Norms assessment.
Grunt is offline
post #8 of 14 Old 11-12-2015, 09:52 PM Thread Starter
Likes (Given): 57
Thanks for the input. I will pull the muffler this weekend and have a look. I will also give a good look around for any signs of a nest.
Regarding the tuning of the engine, very good point there too, thank you. It was running very nicely when I gave her a little trial run Wednesday morning after we got a few inches of snow Tuesday night into Wednesday.
PowerShift- you asked: Are the revs per minute within specs??????????????????????
I would not be surprised if they are not within spec. Having never done this before, what would be the best way of checking the revs? I can certainly look up what the specs would be online for that year/model, but not sure how to check the revs? Never done that before.
thank you!
post #9 of 14 Old 11-12-2015, 10:06 PM
Here's a few that you can purchase. Normally a snow blower rpm when at full throttle is 3,600 rpm.
Good Luck
Small Engine Tachometer | eBay
Normex is offline
post #10 of 14 Old 11-12-2015, 10:55 PM
could also be an exhaust valve issue
