Old Tecumseh H70 worth rebuilding - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 11-13-2015, 07:13 PM Thread Starter
AriensProMike's Avatar
Thanks (Received): 19
Likes (Received): 58
Bought this old motor in a lot with other parts. It was in a tecumseh box from its replacement. Guy claims it's been sitting since 91 in his basement in the box. I was looking around for a replacement engine block with little luck for the last year. Let me know what you guys think.
ID:	62657   Click image for larger version
ID:	62665   Click image for larger version
AriensProMike is offline
post #2 of 9 Old 11-13-2015, 08:34 PM
Likes (Given): 1878
Likes (Received): 661
a decision you have to make for yourself
post #3 of 9 Old 11-13-2015, 08:41 PM
Likes (Received): 483
The advise I was given when I asked about if it was worth rebuilding a GX240 with a thrown rod was, "take it apart, evaluate it and go from there", that is my advice now. You could weld or JBweld the block if it is going to be for yourself.
post #4 of 9 Old 11-13-2015, 09:21 PM
Thanks (Received): 112
Likes (Received): 298
Won't cost you anything to tear it down and see what the internal damage is, and what else needs doing, but If you cannot find a block, then it's pretty much a moot point. Do you need it for anything?
skutflut is offline
post #5 of 9 Old 11-13-2015, 10:17 PM
db130's Avatar
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
I have a H70 block that I'd be willing to sell and I am in MA.
db130 is online now
post #6 of 9 Old 11-13-2015, 10:23 PM
Grunt's Avatar
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3331
Likes (Received): 678
From the serial number starting? with 0, it appears to be a 1970 model??
post #7 of 9 Old 11-14-2015, 07:16 AM Thread Starter
Thanks for the help guys. I was going to use it on my 1974 10,000 series. I got a predator hemi but was trying to keep it original as possible first. DB where in MA are you located? What's the condition of the block? Thanks Mike
post #8 of 9 Old 11-14-2015, 09:34 AM
Jackmels's Avatar
Thanks (Received): 194
Likes (Received): 814
I have Blocks as well as complete running engines, Hudson Ma 978 5628958
Jackmels is offline
post #9 of 9 Old 11-14-2015, 11:58 AM
Thanks (Given): 587
Thanks (Received): 765
Likes (Given): 4344
Likes (Received): 1731
Or look for a blower with a H70 for cheap but in decent shape. Swap the Tec to your Ariens and put the Predator on the parts donor and sell it.
Just depends on how good a deal you can find and how badly you want to mount a Tec on the Ariens. You might break even.
