New To Me (Maybe) Toro CCR 2000 - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 11-18-2015, 05:01 PM Thread Starter
Likes (Received): 18
I'm thinking about picking up a used Toro CCR 2000 snow blower off of CraigsList. The ad says that it is a Toro2000, I assume s/he means CCR 2000. It also says that it starts, but doesn't stay started. I'm not even close to an expert on engines, but if I can get this for a song, then spending some time and a little cash to get it running might be a fun project.
If/when I go look at it, what should I look for?
I assume the problem is in the carb., probably dirty, are there any other likely culprits that might cause this problem that I can be on the look out for?
Smolenski7 is offline
post #2 of 12 Old 11-18-2015, 05:45 PM
Grunt's Avatar
Thanks (Given): 273
Thanks (Received): 329
Likes (Given): 3298
Likes (Received): 671
Being this is a two cycle motor, leaking crankcase gaskets or crankshaft seals could be a "possible" problem. Two strokes rely on compression AND vacuum to function correctly. Unless the engine has a cracked block or scored piston and cylinder wall, it could be a cheap fix. Hopefully the owner didn't run it and ruin it on straight gas.
post #3 of 12 Old 11-18-2015, 05:55 PM
Thanks (Received): 173
Likes (Given): 409
Likes (Received): 651
not sure about the ccr 2000, but the paddles on my ccr 6053 are a bit pricey up here !
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #4 of 12 Old 11-18-2015, 10:33 PM
Thanks (Received): 112
Likes (Received): 297
We pay too much for everything up here....
skutflut is offline
post #5 of 12 Old 11-18-2015, 11:37 PM
how much do they want?
post #6 of 12 Old 11-19-2015, 09:53 AM
Thanks (Given): 224
Thanks (Received): 294
Likes (Given): 1873
Likes (Received): 656
most likely its a carb problem. make sure the scraper bar hasn't worn away and the housing around the auger isn't ground down
post #7 of 12 Old 11-19-2015, 11:21 AM
Thanks (Given): 102
Likes (Given): 271
Smolenski, I've owned a couple of these Toros and the parts are really expensive unless you can find good, used parts. I bought what appeared to be a really nice CCR2000E for $US100 and ended up putting a couple hundred more into it and it still wasn't right. It was a huge error on my part even though the machine looked nearly new.
uberT is offline
post #8 of 12 Old 11-19-2015, 01:07 PM Thread Starter
$50. I definitely will not pay that much for it though. A new carb. is north of $150. That would be a total of $200 and that doesn't include a scraper or paddles. At that point, I could buy new.
Thanks for the advice and warnings. I have contacted the owner, but haven't heard back yet.
post #9 of 12 Old 11-19-2015, 01:18 PM
Thanks (Given): 224
Likes (Given): 1873
new carb
Toro CCR2000 CCR3000 Snowblower Mikuni Carburetor Carb 81 4690 81 0420 95 7935 | eBay
I'm not saying its cheap but not $150 either
post #10 of 12 Old 11-19-2015, 01:24 PM
Likes (Given): 409
$50 x 2 .
28 " Ariens Sno Tek
Toro CCR ss
