Help with 4 way chute control.... - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 11-19-2015, 05:38 PM Thread Starter
Thanks (Given): 11
I have the 4 way chute control that sppears to be a design flaw right from the start. Its on the '06 Craftsman (MTD)#247.88790 9hp Tec 28"
Pull trigger on and push forward deflector throws snow low, pull and deflector throws snow high.
Grab handle and shift to left chute rotates and throws snow left, Shift to right and chute rotates and throws snow right.
These are controlled by cable. I am trying to manuver the chute easier!
In the increasingly cold weather the chute gets harder to rotate. I have used white lithium grease where the chute tube and the mount connect together, I have also tried to oil the cables. When I remove the the drive mechanism from the chute the controls rotated by the cables move freely. As soon as I connect it back, The chute is very difficult to rotate. I am wondering if the mounting surfaces are not mating properly. Anyone have any experience with this ill designed chute? TIA
Marc Fish
Capital District area, NY USA
2 stage Engine #LA318SA-156554
'95 Craftsman II (???)#536.886360 10hp Tec 30"
2 stage TracPlus (reclaimed)
Opfoto is offline
post #2 of 5 Old 11-19-2015, 07:48 PM
db9938's Avatar
Thanks (Received): 143
Likes (Received): 297
I'd still suspect the drive mechanism or control mechanism. Check to make sure that there is no binding or slop in either the control stick, or the control surface axles.
I have a two way controlled MTD with a similar mechanism, and if my memory serves me correctly, it has plastic axles.
post #3 of 5 Old 11-23-2015, 12:09 AM
Thanks (Received): 112
Likes (Received): 298
Try removing the lithium grease. Maybe it stiffens the colder it gets. Does the chute drag if you manually rotate it with the cables disconnected? Any visible rough spots on either the base of the chute or top of the discharge tube? There probably needs to be some slop in the mating surfaces so things don't bind from too snug a fit.
Work fascinates me.
skutflut is offline
Thanks Opfoto thanked for this post
Likes Opfoto liked this post
post #4 of 5 Old 11-23-2015, 08:55 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
I agree... chute controls like yours don't provide much leverage, and the "drag" from the grease could be causing the problem.
Instead of grease, you might try oil where the chute meets the housing? I'd suggest something like 80W-90 oil for manual transmissions, or possibly 10W-40 motor oil. I'd stay away from thinner oils, as they might not stay put.
ELaw is offline
post #5 of 5 Old 11-23-2015, 03:26 PM Thread Starter
Thanks (Given): 11
So I tried to remove the white lithium grease with greased lightning, was able to get some off. Then I tried to move the chute without the cables attached. It seemed a bit tougher without the grease. I then used some gear oil that I think is 80-90 weight. I applied it on the on the "rim" of the chute mount, then smeared some on the tube where it mates to the mount. It seemed to rotate better by hand. I also noted that the cables seem to have excessive slack in them. I saw them peeking out when I made the connection and tried the joystick control. I was too cold to try to tighten them. That may be a contributing factor as well. I wil fireup the kerosene heater and warmup the shed and try to tighten the cables, hopefully we are on the right track.
Marc Fish
Opfoto is offline
