Wiring help on Ariens Heated Hand Grips - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 11-20-2015, 03:38 PM Thread Starter
Thanks (Given): 44
Thanks (Received): 14
Likes (Given): 235
Likes (Received): 47
Hey Guys / Gals see my video, sorry for the bad audio, should have taken off the water proof case.
2016 Ariens Deluxe 28 SHO AX306cc (921044) | Drift Cutters | Front Weight Kit | Handwarmers
1965 Ariens 10ML60D with 1970 10,000 Series Sno-Thro Attachment 10995 | Tecumseh H70-130216G (7HP)
2016 Ariens Razor SP Mower AC159cc (911175)
2016 Predator 8750 Peak/7000 Running Watt Generator 13HP 420cc (69671)
Elt31987 is offline
Likes RattlerGUNZ liked this post
post #2 of 11 Old 11-20-2015, 06:36 PM
Likes (Received): 82
To extend your wire you need either 16 gauge or 18 gauge wire but 16 is preferable and just strip both and solder them together but just before put a 3 to 4" piece of shrink tubing so after you will use a heat gun which once done everything will be waterproof. Good Luck
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
Likes Elt31987 liked this post
post #3 of 11 Old 11-20-2015, 06:40 PM
liftoff1967's Avatar
Thanks (Given): 36
Thanks (Received): 45
Likes (Given): 65
Likes (Received): 94
+1 what Normex indicated
liftoff1967 is offline
post #4 of 11 Old 11-23-2015, 08:16 AM Thread Starter
Thanks (Given): 44
Likes (Given): 235
Good info, looks like i'll need to find someone with a soldering kit and heat gun or buy one, i just don't know if i would ever use it again. So strip both ends and solder them together, then wrap that in shrink wrap and heat gun it. What do you mean by "But just before"? wouldn't i solder the pieces together, let it cool and then wrap it and heat gun it?
Elt31987 is offline
post #5 of 11 Old 11-23-2015, 09:29 AM
Thanks (Received): 112
Likes (Received): 298
Think he means that you slide the heat shrink tubing onto the wires BEFORE joining and soldering them. One they are soldered, you can't get the shrink tubing on. Make sure to keep the shrink tubing out of the way while soldering, or it will get hot and shrink before you have a chance to slide it over the connection.
Work fascinates me.
skutflut is offline
Thanks Elt31987 thanked for this post
post #6 of 11 Old 11-23-2015, 09:45 AM Thread Starter
Thanks (Given): 44
Likes (Given): 235
That Explains it, thanks skutflut and Normex
Elt31987 is offline
post #7 of 11 Old 11-23-2015, 03:26 PM
Yes +1 with Skut and if you're in a jam you can use a regular propane torch but heat the shrink from farther. A bit more tricky but very do able.
Try to get quality heat shrink the ones that oozes like a wax at each end which makes it very waterproof. Good Luck
Normex is offline
post #8 of 11 Old 12-01-2015, 10:16 PM Thread Starter
Thanks (Given): 44
Likes (Given): 235
Completed my first soldering and wrapping. Looks pretty good to me. Now I just need to Dremel out the spot for the rocker switch
ID:	65250   Click image for larger version
Elt31987 is offline
post #9 of 11 Old 12-01-2015, 10:28 PM
Good work, was the heat shrink oozing when you heated it, if yes it could stand more heat at each end where you would see it oozing out.
It has to be purchased with the oozing action that would be shown on the package. Don't worry if it was not with ooze type just put a dab of caulking on each end for waterproofing.
Normex is offline
post #10 of 11 Old 12-01-2015, 10:42 PM Thread Starter
Thanks (Given): 44
Likes (Given): 235
My Home Depot didn't have the oozing type but good idea on the caulking, I have a new tube of clear caulking so that's perfect
Elt31987 is offline
