single stage- wheel removal - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 11-21-2015, 06:26 PM Thread Starter
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 418
Likes (Received): 664
any tips on removing those " caps" that hold the wheels on single stage blowers ? my toro has a cracked tire . bought a replacement, but cant get the little cap thing off. no issue with using a grinder and drilling for a cotter pin and washer !
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #2 of 6 Old 11-21-2015, 06:51 PM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1741
Tried a service manual, nothing.
If it's the little metal "hat" that gets pounded on the shaft I'd use a prybar or screwdriver between it and the tire to try and pry it off the shaft. Bend it enough to get a vice-grip or diagonal cutter on it and twist the heck out.
Before I drilled and pinned I'd check out a dealer or a few hardware or big box stores for the replacement.
Toro 3290-320 ?? Not sure if this is the one for your machine.
post #3 of 6 Old 11-21-2015, 07:59 PM Thread Starter
Thanks (Given): 82
Likes (Given): 418
i think its a standard 1/2" axle. tried prying the crap out of it, no go. big channel lock plyers no go. thanks for the info on the cap. might gust gently grind it off and replace .
28 " Ariens Sno Tek
Toro CCR ss
post #4 of 6 Old 11-21-2015, 08:20 PM
Thanks (Given): 173
Likes (Given): 457
Likes (Received): 1032
Lowe's carries those caps. They should be the common spring finger type. Never saw one that wouldn't come off with a little stromg arming.
post #5 of 6 Old 11-21-2015, 08:25 PM Thread Starter
Thanks (Given): 82
Likes (Given): 418
rough prying and channel lock plyers with no success . on to the angle grinder ! lol
28 " Ariens Sno Tek
Toro CCR ss
post #6 of 6 Old 11-21-2015, 09:41 PM
Thanks (Given): 589
Likes (Given): 4358
Ya gotta do what ya gotta do !!
Careful with that grinder. Luckily you don't have to worry about any damage to the wheel since it's junk.
