Toro 824 XL snowblower will not drive - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 11-21-2015, 07:59 PM Thread Starter
Hello,
I have had issues with my Toro snowblower failing to drive when lever is engaged. Wheels will somewhat turn when no real pressure is on the machine. I lifted it up and opened belly pan and belt seems to be ok, friction wheel is engaging the plate. However I see some issues with the drive gears. The main axle gear might not be fully touching the sprocket. is there an adjustment for this? Is this a common problem?
Thanks.
kep890 is offline
post #2 of 5 Old 11-21-2015, 08:16 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 418
Likes (Received): 664
pics would be great on this one ! gears not meshing is not as common as belts slipping etc , jmo
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #3 of 5 Old 11-22-2015, 05:46 AM
Likes (Received): 1379
Post a pic or vid of this problem presenting itself unto us. ALOHA from the paradise city.
post #4 of 5 Old 11-22-2015, 07:32 AM
Thanks (Received): 35
Likes (Received): 81
could be worn bushings letting the gears move apart. Pics or better yet video will make finding the problem much easier.
CarlB is offline
post #5 of 5 Old 11-22-2015, 08:30 AM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1741
Welcome to the forum Kep
Worn bushing, stretched chain. Posting the model and serial number of the machine will help us look up an exploded diagram.
It could be a model 38066, 38083, 38084 or 38086 ??
On a machine I had the bushings "6:1" on the diagram were shot and allowed poor contact between the gears. I replaced the bushings and also drilled the cluster to install a grease zerk. Had to make a new shaft as the gear had eaten into it when it ran out of bushing. I give it a shot or two of grease in summer when I'm going over them.
Name:	1032 Craftsman Drift Breaker gear cluster.jpg
ID:	64066   Click image for larger version
Name:	040314 JA343474 Disc pivot shaft 1.jpg
