B&S Dual Circuit Stator LED Question - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 11-22-2015, 09:13 AM Thread Starter
Brother Al's Avatar
Thanks (Given): 10
Thanks (Received): 21
Likes (Given): 21
Likes (Received): 35
Hello,
Ive followed the LED thread for quite awhile. I too am upgrading my machine with LED lighting... I initially initially believed that I could simply convert my 1971 B&S 7hp engine to a dual circuit stator and utilize the DC lead for powering the LEDs. I intend to reserve the AC wire for additional items down the road...
As I near completion, Im now unsure if the "DC" lead is actually clean enough to use with LEDs, or if I should add an additional rectification? I do intend to add a capacitor to balance it.
Another question is, should I be adding a voltage regulator to protect the LEDs? or would the LEDs be capable of handling unregulated voltage?
I have not tested the machine's actual power output with a multimeter yet, because she is still apart... still waiting for a few parts to come in. I was hoping someone has the answers, so I can avoid a potentially expensive experimentation process.
__________________________________________________ _____
"Corp America Got Bailed Out, WE Got Sold Out"
May the Tin Indian and JZD Rest in Peace
Prius, Proof that people will buy Anything, (Baaaa Baaa)
All the Answers to our Problems can be found in the Boneyard!
God Bless America & those who serve & have served our Country!
Brother Al is offline
post #2 of 3 Old 12-03-2015, 01:38 AM Thread Starter
Brother Al's Avatar
Thanks (Given): 10
Likes (Given): 21
Anyone?
post #3 of 3 Old 12-03-2015, 07:06 AM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
Hey Brother Al,
You'd have to see if the "DC" line is rectified using a single diode or a bridge rectifier.
If it's a single diode, you're only getting 1/2-wave rectification; 1/2 of the sine wave is being blocked.
Since you have it apart, I recommend removing it if possible and replacing the single diode with a bridge rectifier in addition to a smoothing capacitor.
If you already have a full-wave rectifier, than a large smoothing capacitor is all that's really required.
A voltage regulator isn't completely necessary if it's always "on". Adding a switch creates an entirely different monster since a no-load condition can create a relatively high voltage at the stator output that may smoke your LED lamp when you toggle the switch.
('87 Toro 38150 826)
