Auger gear case grease - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 11-26-2015, 07:41 PM Thread Starter
GoBlowSnow's Avatar
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 268
Hi all-
I've been working on an old John Deere TRS-27 (yes I know, Murray built) but have managed to get the engine running right and today thanks to you folks for the suggestions on getting a mini tachometer, I got the engine RPMs adjusted to between 3500-3550 (manual says 3700 but not feeling like taking a risk blowing up an 8hp Tech engine)
The next thing I turned my attention to was greasing the auger and other spots that have the zerks around them. And then I was curious, so I took the fill bolt off of the auger gear case, and stuck a nail down in there. Seems like it is bone dry. Not good. Now with that said- I believe, but am not 100% certain that this type of gear case takes grease and not the 80W90 gear oil like on newer machines. This one is a late 80s vintage. So. The question now is- is that in fact the case? Grease and not oil? Next question- do I simply fill that thing up with grease, to the top? I've been trying to find a operators manual online for this machine but am not having much luck. I downloaded a service/technical manual but I could not find any reference to oil or grease. Just how to take the thing apart.
Also, as for the grease, I figured using Mobil-1 automotive synthetic grease that meets or exceeds the proper specs.
Advice? Feedback?
Thank you
GoBlowSnow is offline
post #2 of 15 Old 11-26-2015, 08:02 PM
Normex's Avatar
Likes (Received): 82
Originally Posted by GoBlowSnow View Post
Hi all-
Look at page 39.
http://download.snowblowerguide.com/...1466-06580.pdf
As for my Ariens St-1130DLE I use both, grease and synthetic gear lube.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #3 of 15 Old 11-26-2015, 08:19 PM
Likes (Received): 303
If your computer is as slow as mine this will be easier
post #4 of 15 Old 11-26-2015, 08:41 PM
Thanks (Received): 112
Likes (Received): 298
Who knew that were that many choices for grease
I wonder why they have one listed that's good to 80 degrees F? Hardly ever snows at that temp.
Work fascinates me.
skutflut is offline
post #5 of 15 Old 11-26-2015, 08:56 PM
Normex's Avatar
I wonder why they have one listed thats good to 80 degrees F? Hardly ever snows at that temp.
One thing to watch for is when blowing snow check after if there is snow
on the gear box then it indicates you have no problem with lubrication there but if it's melting and even a wisp of vapour then you have to ascertain you have enough of grease or oil.
This in part answers why it's good to 80 deg. Far.
Normex is offline
Likes Biketrax liked this post
post #6 of 15 Old 11-27-2015, 11:36 AM
I would use either an 80w90 gear oil if the case is sealed well, or a 00 grease if the oil will leak out. One thing to think about with the automotive differential oils is some of them will attack brass and bronze metals. I have never seen it personally, but there are plenty of warnings on various forums online. It has something to do with GL3 vs GL4 vs GL5, but I don't think it is as big of a problem now with modern oils.
post #7 of 15 Old 11-27-2015, 04:37 PM Thread Starter
GoBlowSnow's Avatar
Likes (Given): 57
Thank you very much!
post #8 of 15 Old 11-13-2016, 04:03 PM
Grease + gear lube
Do you mean you mix grease and gear lube in the crankcase?
I ordered L3 Synthetic Gear Lube based on the manual for my Ariens ST924 (1994-96 era) but when I went to fill it, it was loaded with grease. The lube I bought is red and thin, like transmission fluid. Will these mix?
CapeCodDave is offline
post #9 of 15 Old 11-13-2016, 06:18 PM
Cardo111's Avatar
Thanks (Received): 127
Likes (Given): 79
Likes (Received): 172
No he meant the auger gear case.
Cardo111 is offline
post #10 of 15 Old 11-25-2016, 05:59 PM
Normex's Avatar
I meant yes in the auger gear case I have both synthetic lube and grease, as if they mix well together all I know the gears are fully lubed to do their work.
Norm
Normex is offline
