Flywheel/Stator Upgrade vs Adjustable Step-Up Converter ~~ Is it possible? - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 12-01-2015, 11:25 AM Thread Starter
Likes (Received): 6
Another DC power issue...I don't think I'm getting the full potential of lumens from my lights due to a possible lack of juice. I have not metered my output nor checked the flywheel/stator but my stock wiring is set up for electric start, warmers, and light (only using warmers and lights). Being that stators ranging 18W - 84W are available I'm thinking I may have towards the higher end since my stock inline fuse is 7.5amps.
I have no need for electric start but because the length of my drive (150 + parking) is no quick job, I would like, in addition to grips and lights, want to power my beverage warmer.
My question is, IF I am at the low end, can I add an Adjustable Step Up Converter which would allow me to adjust for appropriate range of Volts and Amps so as not to fry anything, yet take advantage of the increased watt output generated?
I have zero electrical intellect and my research and reading in an attempt to educate my self has given me a migraine.
.......my guess is, I am not even on the right path in my thinking and it can only be achieved by upgrading flywheel/stator.
My wiring - Bolens 1026 Owner's/operator's Manual (Page 25 of 26)
I installed redundant inline fuses and on/off switches for both lights and warmers.
My lights - 2X 6inch 18W LED Work Light Bar Flood Beam Offroad Driving Fog 4WD Lamp Ute SUV | eBay
Could I install a Step-Up, if so, a recommendation, and how?
Maybe something like this
DC DC LTC1871 Boost Step Up Module 3 5 to 30V 100W 100W LED Voltmeter | eBay
Bolens93 is offline
Likes E350 liked this post
post #2 of 17 Old 12-01-2015, 12:06 PM
Thanks (Given): 573
Thanks (Received): 750
Likes (Given): 4247
Likes (Received): 1683
You can step up the voltage with a transformer but you can't increase the power available. In fact the transformer will use some of the power due to resistance and heat and leave you with a higher voltage but less amperage then you have now to run stuff.
The only way to get more power is a flywheel with more magnets and or more windings on the stator.
Check your voltage on the circuit with the lights. If the voltage is dripping below 12 volts with both hooked up then you'll only be able to run one light.
That or replace the stator and or flywheel.
post #3 of 17 Old 12-01-2015, 08:35 PM
Likes (Received): 20
All of the Bolens that Ive dealt with (that came stock with heated grips) already had the Tecumseh 5-magnet flywheel (p/n 611094) and 7amp (84w) coil installed from the factory. That's about all you can do other than add a battery to run your beverage heater.
sidegrinder is offline
post #4 of 17 Old 12-02-2015, 01:36 PM
db130's Avatar
Thanks (Given): 16
Likes (Given): 241
Likes (Received): 200
Beverage warmer?? Come on, man.
How about a photo of the 18w lights in action? Any flicker?
db130 is online now
post #5 of 17 Old 12-02-2015, 01:52 PM
E350's Avatar
Thanks (Given): 280
Thanks (Received): 62
Likes (Given): 159
Likes (Received): 77
Guys, I like this thread. In keeping with my duty to ask the stupid questions on this forum, are there any tiny (low drag) alternators out there which can be hooked up to an existing or fabricated power take off?
E350 is offline
post #6 of 17 Old 12-02-2015, 03:09 PM
db130's Avatar
Thanks (Given): 16
Likes (Given): 241
Tecumseh did make a rare add-on alternator for engines built after 01/01/1988, for HSK Compact, HSK30-35, HSSK40-50, HSK50-60-70, HMSK70-80-100, and OHSK120 engines.
These engines typically have a sticker on the recoil starter that says, "This engine is provisioned for an electric starter and the add-on alternator kit"
You can tell by 3 holes 60-degrees apart on the recoil starter.
Here is a picture of it
My late 80s/early 90s Bolens 824A that I parted out had such an engine.
db130 is online now
post #7 of 17 Old 12-02-2015, 04:17 PM
Likes (Received): 280
Very cool I have never run into that type of altenator before. Never really need a beverage warmer on my blower either! ;>P It does get me to thinking if there are some small magneto type alternators you could adapt? I can't find any descriptions of this guy that tell me much about it: DB Electrical - NEW PERMANENT MAGNET ALTERNATOR KOKUSAN DENKI GP9905 8970489700
Looks like it might have a chance to work though?
post #8 of 17 Old 12-02-2015, 10:37 PM
I added a Honda motorcycle alternator (~25a/300w) to a Tecumseh powered snowblower about 20yrs ago. It worked well and really didn't take very long, but Im a pretty good metal fabricator.
post #9 of 17 Old 12-03-2015, 01:04 AM
E350's Avatar
Thanks (Given): 280
Likes (Given): 159
Yep, very cool guys.
And one more thing Bolens93 would you please post a picture of your beverage warmer?
E350 is offline
post #10 of 17 Old 12-03-2015, 04:49 AM Thread Starter
Likes (Received): 6
Zero flicker. I will post a pic or vid soon when I RE-install them....rethinking where I had put them I feel they would have been compromised either by plowing into deep snow or from throwing snow so I removed them from the intake and am looking at installing on the dashboard. I have an old mt bike bar that I will cut in half.
Bolens93 is offline
