Tecumseh H70 diagnosis (video) - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 12-04-2015, 08:58 PM Thread Starter
Spoke about this machine in another thread but feel this is a different question.
Have the engine running but can't adjust it correctly and hoping some guru's can help me out.
Here is a video of it running. Sorry it's at night but I've done my best with lights. Tried to show the small sputtering of smoke near the end.
https://goo.gl/w3zT3n
What I've done so far:
New aftermarket carburetor
New spark plug
Oil change
New points and condenser
New head gasket
Any help or advise welcome
I'm thinking I may not have gaps points perfectly (learnt by watching videos) and so timing might be off. Wondering if going down the nova II route might be the best option.
Nconroy1 is offline
post #2 of 12 Old 12-04-2015, 09:53 PM
Thanks (Received): 36
Likes (Given): 38
Likes (Received): 126
New spark plug
Oil change
New head gasket
It does sound like an ignition issue to me... but then again I'm far more familiar with Porsche flat 6's than Tecumseh flat heads.
Kirk Engines has come out with a new electronic ignition module if you decide to go that route...
Kirk Engines, Inc. >> Garden Tractor Performance Parts
A lot of valuable information here, worth a read ...
How to Accurately Set the [Point] Ignition Timing on Virtually Any Gas Engine
How to set the [point] ignition timing on the aluminum block flathead Tecumseh engines
Crank Trigger Electronic Ignition Section
Using Crank Trigger Electronic Ignition on a Cast Iron Block Briggs & Stratton or Tecumseh Engine
russkat is offline
post #3 of 12 Old 12-04-2015, 10:15 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
Sounds like she's over-revving at the 20s mark...get a tach on that baby! 3600RPM max.
('87 Toro 38150 826)
Likes scrappy liked this post
post #4 of 12 Old 12-04-2015, 10:27 PM
Thanks (Received): 41
Likes (Received): 98
Agree it' sounds like over 3600.
Did you shut it down at the end or did it stall?
Hard to tell.
scrappy is offline
post #5 of 12 Old 12-04-2015, 10:45 PM Thread Starter
At the end I shift the lever to shut it down, not got a tach but one is on the way.
Would the over revving cause the sputtering?
I move the lever to fast around the 20s
adjusting the rpm is done by moving the governor arm right?
Nconroy1 is offline
post #6 of 12 Old 12-04-2015, 11:27 PM
Thanks (Received): 143
Likes (Received): 297
Agree on the tach, might also consider the valve adjustment.
post #7 of 12 Old 12-04-2015, 11:45 PM
Thanks (Given): 231
Likes (Given): 2041
it's hard to say from the video...the stock valve springs start to lag as you exceed max 3600rpm.
the first thing that you want to do is sync the governor with the carb throttle; the process is described in the l-head service manual & there are a few videos on youtube. Since you're using an aftermarket carb, your linkage might be off. Adjustments should be made to the spring tension...not to the arm itself.
post #8 of 12 Old 12-06-2015, 12:03 PM
Thanks (Received): 15
Likes (Received): 19
RPM Gauge is a free phone app to get your speed in the ballpark
cpchriste is online now
post #9 of 12 Old 12-07-2015, 09:56 AM Thread Starter
Thanks for the replies.
I downloaded a similar app for Android. Does RPM Gauge use the proximity sensor? How do you use it to measure the small engine?
From the flywheel? or belts?
Nconroy1 is offline
post #10 of 12 Old 12-07-2015, 09:58 AM Thread Starter
Could you point me in the right direction to one of these videos please?
I have only found the ones that show the original position of the linkages etc...
Nconroy1 is offline
