valve stem lube - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 12-11-2015, 09:41 AM Thread Starter
AL-
Thanks (Given): 7
Likes (Received): 29
valve stem lube
I'm going to lap in a couple of valves and think I need to valve stem lube. Briggs and Stratton has this product but locally it hard to find. is there another brand or substitute that I might use. thanks
Weather is another subject, high of 48 here today and mild for the seven day forecast.
AL- is offline
post #2 of 6 Old 12-11-2015, 09:48 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
I'd use engine oil. It's what lubricates the guides all the rest of the time... it should be okay in this circumstance also.
ELaw is offline
post #3 of 6 Old 12-11-2015, 10:08 AM
Likes (Received): 280
that's what I have always used.... I didn't know they made special lube actually
post #4 of 6 Old 12-11-2015, 10:31 AM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1739
For the valve stem engine oil should work fine.
You already have the lapping compound ??
Canada
Canadian Tire Powerbuilt Powerbuilt Valve Lapping Compound : Questions, Answers, How To, FAQs, Tips, Advice, Answers, Buying Guide
U.S.
VersaChem 13209 - Valve Grinding Compound | O'Reilly Auto Parts
Permatex Valve Grinding Compound (1.5 oz) 80036: Advance Auto Parts
post #5 of 6 Old 12-12-2015, 09:13 AM
I have always used any engine oil that I had on hand. Never a problem and I have built some serious V8's. Valve stem lapping oil is an example of good marketing and little else.
Lock45 is offline
post #6 of 6 Old 12-12-2015, 11:12 AM
Thanks (Received): 35
Likes (Received): 81
I use engine assembly lube just because i have it on hand for assembling V8 engines, but for a simple valve job on a small engine oil is fine.
CarlB is offline
