Best way to clean a snowblower body (spay and wipe) - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 12-15-2015, 07:45 AM Thread Starter
Likes (Received): 483
Snowblowers that had ben sitting for a long time or not being cleaned regularly tend to get dirt/grease or other spot marks on them, what is the beat way to remove them without using a power washer. Let say using a spray and wipe method. Thanks for your imput.
post #2 of 15 Old 12-15-2015, 07:51 AM
Thanks (Received): 379
Likes (Received): 1377
Palmolive dishsoap and a hose.
Likes AriensPro1128 liked this post
post #3 of 15 Old 12-15-2015, 09:18 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
I'm sure others will disagree but I'd *never* use a power washer on a snowblower! IMHO there's too much potential to get water in places where it shouldn't be... inside the tractor housing, in the gearbox, under loose paint or powdercoat.
If the machine was really greasy or dirty I might actually use Dow bathroom cleaner aka "scrubbing bubbles". It's not really harsh like Gunk, but does a good job of loosing dirt and grease.
If the machine is not that dirty I might use hand dish detergent like powershift suggested, or car-washing soap.
ELaw is offline
Likes AriensPro1128, detdrbuzzard liked this post
post #4 of 15 Old 12-15-2015, 10:04 AM
Thanks (Given): 14
Thanks (Received): 17
Likes (Given): 36
simple green/water mix. hand wash with 3m sided sponge. Once grease and dirt are removed, repeat with fresh clear water. Dry with micro fiber cloth...
250cc B&S (1150 ft lbs)
Loco-diablo is offline
post #5 of 15 Old 12-15-2015, 10:06 AM
E350's Avatar
Thanks (Given): 280
Thanks (Received): 62
Likes (Given): 159
Likes (Received): 77
Gasoline and a scrubby $2.15/gal. at Costco. Followed by Purple Power $5/gal at Walmart.
E350 is offline
post #6 of 15 Old 12-15-2015, 10:22 AM
loneraider's Avatar
Thanks (Received): 14
Likes (Received): 15
Thumbs up
Mean Green it than warm soap and water & you can still take a garden hose to it but it should be cleaned before you do your pre winter checks and before you spray all the cables ect.. do all this before the snow hits/
Ariens deluxe 28
Ariens 927le
ariens self propelled mower
loneraider is offline
post #7 of 15 Old 12-15-2015, 10:27 AM
Thanks (Received): 33
Likes (Received): 54
Light film, I'd use something citrus base.
Medium muck - maybe the same, and just let it dwell.
Anything much more, out comes APC. Spray, let it dwell, agitate.
Between dwell time and agitation, most of anything should rinse clean under soft water hose..
Straight up grease/dirt, time is $, so out comes the solvents, then a quick rinse....and then either citrius or APC. Pick your poison
mobiledynamics is offline
post #8 of 15 Old 12-15-2015, 11:02 AM
Thanks (Given): 587
Thanks (Received): 765
Likes (Given): 4349
Likes (Received): 1731
I understand fully, I used to mix dry Tide with gasoline when I was a kid and it cut grease like nothing else I've ever tried. But only out of luck my parents house is still standing as back then I had no idea how easy it was to light gas vapor on fire.
Don't use gasoline for any cleaning. It's just too dangerous and you never know where you might get a source of ignition and burn down not only the thing you're cleaning but possibly the garage or even yourself.
Just pick up a can of engine cleaner at Walmart or an auto parts store and use that or Diesel. The problem with gas is the vapor will run along the ground and it's invisible. It can be ignited by something a number of feet away and travel back.
I'd also recommend not using a pressure washer and just gently scrubbing it and wiping it off as many times as necessary. If you do choose to use a pressure washer try to do it on a warm sunny day, use air to blow it off, run the engine for a bit and start lubing everything back up.
post #9 of 15 Old 12-15-2015, 12:56 PM
E350's Avatar
Thanks (Given): 280
Likes (Given): 159
So, during the Summer of my 11th year I was working at the local softwater company and while I was filling tanks to load on the delivery truck it suddently started and roared out of the building. Next thing all I saw was orange and red flames, but I knew where the overhead door was and ran. The secretary said my boots were on fire.
Apparently, the automatic shutoff nozzle had failed to stop filling the truck and the gasoline vapor on the floor, not the liquid, ran along the ground 25 feet or so under the tenant partition to the pilot light in the gas water heater next door.
I had just finished painting the tanks and all the galvanized lines with the appropriate colors to designate evacuation and fill, as well as the front of the building.
The rest of that Summer when I wasn't out riding in the truck doing softwater tank deliveries, I repainted everything again. Woodland can get hot in the Summer, in excess of 100F, so I wasn't pleased.
Not only do I do my I suggested cleaning outside, but I also never have the fuel container anywhere close to where I am cleaning.
So, I am kinda aware of the danger, but even I should probably rethink my solvent suggestion.
So, unless you have a similar experience in your past, best to take Kiss4aFrog's advice and stay away from the gasoline...
* I guess the quick action of our route driver saved my life. Not even one hair on me got so much as a singe, but I did have to buy new boots.
E350 is offline
post #10 of 15 Old 12-15-2015, 01:52 PM
Likes (Given): 1878
Likes (Received): 661
i usually have a bottle of s100 motorcycle cleaner on hand for the greasy stuff other wise what ever soap is in the garage for the tintops will do for the snowblowers too and no power washing either
