Old Sno Thro rebuild - Snowblower Forum : Snow Blower Forums
post #1 of 23 Old 12-15-2015, 10:58 AM Thread Starter
I have a old Sno Thro i working on. Model H60-7500 3H ,Serial #8197 16144. I need a diagram...pic...or something for the linkage on carb for throttle and governor. Springs are missing, and if i had one i wouldn't know where to put it. I have found a few online but are not quite the same carb as mine...mostly H60's. Does anyone have or know of a place to find a diagram? Right now it only runs wide open. I'm attaching a pic of mine,(hopefully),and don't pay attention to the spring,it's just something i dug up to try.Old Sno Thro rebuild-carb.jpg
Last edited by sscotsman; 12-15-2015 at 11:45 AM. Reason: Engine model number corrected.
ugeely is offline
post #2 of 23 Old 12-15-2015, 11:24 AM
Likes (Received): 42
Hi ugeely,
Welcome to the SBF. Check on this link for the Tecumseh manual...page 33 lower right is for old "Snow King" engines. Looks like what you have. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #3 of 23 Old 12-15-2015, 03:59 PM
Thanks (Given): 276
Thanks (Received): 330
Likes (Given): 3348
Likes (Received): 679
ugeely. Sorry MH, my manual shows figure 25 on page 32 as the correct picture, I think. It also looks like item #220 on the parts list and is Tecumseh part number 30826 which costs $2.50. ugeely, small engine throttle springs are designed to supply the correct tension and "should not" be substituted with a spring that "looks like it will work" at the risk of over speeding and blowing up your motor.
post #4 of 23 Old 12-15-2015, 11:08 PM
Thanks (Given): 24
Thanks (Received): 34
Likes (Given): 15
Likes (Received): 24
Check back tomorrow, I will get some pics of mine and post it for you. I could tell you right now that that short spring shouldn't be there. Looks like that one is holding it wide open.
Ray
1962 Ariens 10ML60
1979 Toro 524
1975 MTD Snowflite 4/22
Ray 1962 10ML60 is offline
post #5 of 23 Old 12-16-2015, 08:03 AM Thread Starter
Thank you...I'll check it out.
ugeely is offline
post #6 of 23 Old 12-16-2015, 08:09 AM Thread Starter
Hello Grunt, I think you nailed it. Thanks a bunch.
ugeely is offline
post #7 of 23 Old 12-16-2015, 08:12 AM Thread Starter
Ok Ray, i'll check back. Thanks
ugeely is offline
post #8 of 23 Old 12-16-2015, 09:27 AM
Likes (Received): 303
Here's a pic of mine off an H70.
After looking at it again, just FYI, that is not my gasket glob in the pic. This was an un-retouched carb pic from a project blower with a grenaded Tec 7hp. I may never use it , but if I do, it certainly will be cleaned up to correct standards.
Thanks Grunt thanked for this post
Likes bad69cat, db130 liked this post
post #9 of 23 Old 12-16-2015, 09:29 AM
Don't know if you caught this vid when searching
Check around 1:44 mark
post #10 of 23 Old 12-16-2015, 12:14 PM
Thanks (Given): 590
Likes (Given): 4367
Likes (Received): 1742
Welcome to the forum Ugeely
