Pop off HM80 Tec flywheel - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 12-20-2015, 03:21 PM Thread Starter
AL-
Thanks (Given): 7
Likes (Received): 29
I have been hitting the end of the shaft on a 8 hp tec engine to remove the flywheel.
I don't have the proper tool so have tried prying out and hitting with a 3/4" x 3" brass rod with a hammer . Using the brass to save the threads.
Maybe I should hit harder or I have small air hammer or do I need to use steel on steel to get a good solid impact.
AL- is offline
post #2 of 9 Old 12-20-2015, 03:32 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
This is how I do it:
db130 is online now
post #3 of 9 Old 12-20-2015, 03:47 PM
Thanks (Given): 173
Likes (Given): 453
Likes (Received): 1029
No way would I hit the shaft that hard. Those magnets are glued onto the flywheel. I either use a puller or I apply pressure from the back side and then gently tap the flywheel. That's just too much force imho.
I'd rather buy a flywheel puller than try to find a different flywheel or repair the magnets.
post #4 of 9 Old 12-20-2015, 04:19 PM Thread Starter
AL-
Thanks (Given): 7
There is no way to use a puller on this specific type of flywheel and Tec repair manuals recommend against using a puller on the back of the rim. These are designed to pop off, however in the video the guy is hitting directly onto the end of the shaft and the nut which is not recommended as it might endanger the threads. These magnets may not be glued on?
I read on some of the older models there are provisions (threaded holes) and to use a puller- magnets are glued on.
AL- is offline
post #5 of 9 Old 12-20-2015, 04:26 PM
Likes (Received): 42
I rethread the flywheel nut to just cover the shaft end, apply steady pressure to the back of the flywheel with a flat 16 inch prybar, and give a good, flush rap to the end of the nut with a 3 lb hand sledge. Off it comes, and the nut keeps the flywheel from grenading on the floor. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
Likes 43128 liked this post
post #6 of 9 Old 12-21-2015, 06:28 AM
Likes (Received): 6
i do it the same way. worst case a little heat around the center helps before the whack is applied...
2014 ariens deluxe 28+
fixer5000 is offline
post #7 of 9 Old 12-21-2015, 08:36 AM
the prybar and hammer method works every time for me, just apply a small amount of pressure with the prybar and thread the flywheel nut back on so no threads are exposed and give it a few good smacks until it pops
post #8 of 9 Old 12-21-2015, 09:34 AM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 30
Likes (Received): 43
I wedge behind the flywheel with a couple of big screwdrivers or pry bars, thread the nut on a little past the end, and put a washer on the end so it's flush with the end of the shaft, then rap it with the hammer, works every time.
Sid
Sid is offline
Likes bad69cat liked this post
post #9 of 9 Old 12-21-2015, 06:03 PM Thread Starter
AL-
Thanks (Given): 7
Thanks all... took three good raps
AL- is offline
