Tuning and RPMs Under Load - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 01-13-2016, 06:27 PM Thread Starter
Thanks (Given): 21
I've got a question about tuning the engine on my Ariens. It's an early 70s 5hp Tecumseh. I recently picked up an RPM/hour meter and it works pretty well. I've tuned the engine to just under 3600 RPM at full speed with no load.
My question is: when the auger hits some snow the RPM drops to about 3200-3300. Is that to be expected or should I be able to adjust how much the throttle opens to maintain 3600?
Thanks.
Michael303 is offline
post #2 of 11 Old 01-13-2016, 06:46 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
A tach is some great insurance for minimal investment.
That's a typical RPM drop if you're really stuffing its face.
the only way to really get more out of it would be to boost compression or mess with the impeller pulley ratio (increase torque at the expense of velocity/throwing-distance).
('87 Toro 38150 826)
classiccat is online now
Thanks Michael303 thanked for this post
post #3 of 11 Old 01-13-2016, 07:05 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 420
Likes (Received): 664
i would guess that your rpm drop puts that engine right in its peak torque happy place !
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #4 of 11 Old 01-13-2016, 07:53 PM Thread Starter
Thanks (Given): 21
Thanks for the feedback, guys. I guess I was just hoping to get a little more throwing distance. It works fine but it's not as far as I'd like and on my drive I can end up throwing the snow in the middle twice if it doesn't clear to the side.
Plus this.
post #5 of 11 Old 01-13-2016, 08:03 PM
Thanks (Given): 14
Likes (Given): 44
Likes (Received): 50
Impeller mod would help if u haven't already
Rob711 is offline
Likes classiccat, gsnod liked this post
post #6 of 11 Old 01-13-2016, 09:58 PM
Thanks (Received): 112
Likes (Received): 298
Thanks.
Are you hitting a lot of snow, or just an couple of inches. If its just a bit, maybe the governor needs a bit of adjustment.
If its a good size pile, especially if its wet or heavy, it's normal for an engine to slow down some when its chewing big piles. The governor does the throttle adjusting to keep the RPMs up, but it cannot make the engine provide more power than its designed for. That said, make sure you have the throttle wide open when you are working, because if its set to slower speed, the governor will not be able to maintain power.
Work fascinates me.
skutflut is online now
post #7 of 11 Old 01-13-2016, 10:26 PM
Thanks (Received): 40
Likes (Received): 149
Carburetor tuning/performance could be off. Is it adjustable?
It does not sound out of the ordinary but I have had sound running machines that appreciated an tweak of the high speed needle and responded stronger.
Pete
Spectrum is offline
post #8 of 11 Old 01-14-2016, 11:33 PM Thread Starter
Thanks (Given): 21
The last snow was 3 or so inches. It was a little wet but nothing it should bog down on. I'll take another look at the governing this weekend. I'm not familiar with the adjustments but maybe I can get the throttle open a little more when the governor kicks in.
Thanks again for the feedback, guys.
post #9 of 11 Old 01-15-2016, 06:59 AM
Thanks (Received): 35
Likes (Received): 81
engine may be a little lean. If you have an adjustable carb try to richen it up a little.
CarlB is offline
post #10 of 11 Old 01-15-2016, 09:38 AM
Likes (Received): 6
Thanks.
Sounds like the governor....when settings are at extremes of major and minor it will either dog or over-rev......there is a sticky thread, as well as other posts that have great info
Bolens93 is offline
