'68 Ariens pull chord question - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 01-16-2016, 11:09 AM Thread Starter
Question '68 Ariens pull chord question
Hey I'm new, thanks to Scott's Website I was able to find this great site. Basically in Winter when I'm laid off from paving I shovel this year I decided to get into the snow blowing business and do everything on my own. Got my first Ariens last year it was a friends grandfathers 1968 6 HP Deluxe. Works great everything original but when I pull the chord every time it gets stuck half way on the first pull and then the second pull is fine and it always starts on that second pull. I later Purchased a 1973 8 HP Ariens Deluxe, chord was replaced on it at some point and numerous other things and runs great so I use this as my main machine. I have a 1974 6 HPD also that some guy considered "Junk" That will be a summer restore project which I will film and put on here, but currently use it as a parts machines. I would like to keep the 68 as original as possible is their a way to fix or adjust the chord? Or possibly swap it with the 74? Sorry if this is a newb question I'm used to working on Mack's lol.
mastaboog749 is offline
post #2 of 15 Old 01-16-2016, 11:32 AM
Jackmels's Avatar
Thanks (Given): 111
Thanks (Received): 168
Likes (Given): 373
Likes (Received): 705
A shot of WD or PB blaster on the recoil's center might help. Or, you can tighten the spring one turn by 1) Remove Recoil. 2) Pull rope all the way out. 3) Clamp recoil spool with vicegrips. 4) Cut knot on recoil rope and remove it. 5)while holding recoil spool, remove vicegrips, and turn the spool 1 revolution tighter. 6) clamp spool with vicegrips, thread rope back through, and tie a new knot. Done!
Jackmels is online now
post #3 of 15 Old 01-16-2016, 12:09 PM
Thanks (Given): 181
Thanks (Received): 164
Likes (Given): 1746
Likes (Received): 400
^^^ Marvel Mystery Oil (MMO) works great as well...and --maybe i'm weird-- I like the smell
classiccat is online now
post #4 of 15 Old 01-16-2016, 01:39 PM Thread Starter
Alright def trying some blaster at the recoil center. On the way to the shop now for something else. I put MMO in the spark plug hole when I first got the machine but I am going to do it again today, do some open pulls. Good Ideas guys, if I have to I'll try tightening the spring? I'm just worried by the word tightening because the thing feels pretty **** tight already haha but I can always give it a shot.
post #5 of 15 Old 01-17-2016, 07:50 AM Thread Starter
Helped... sometimes lol. Once and a while now I'm getting first good pulls, but now if I don't get it started in that first good pull then it gets stuck. Didn't try cutting the knot yet though. Maybe something inside the engine?
post #6 of 15 Old 01-17-2016, 08:59 AM
Thanks (Given): 181
Likes (Given): 1746
not exactly the same as your engine but similar concept of how to tighten that spring
post #7 of 15 Old 01-17-2016, 09:26 AM
Thanks (Given): 522
Thanks (Received): 690
Likes (Given): 3912
Likes (Received): 1505
Aren't we all But that's a different forum entirely
The video is on a Briggs but there pretty much all the same. Here are some articles on how to: https://www.google.com/search?q=tecu...er+cord+repair
post #8 of 15 Old 01-17-2016, 11:40 AM
Grunt's Avatar
Thanks (Given): 250
Thanks (Received): 299
Likes (Given): 2997
Likes (Received): 552
After it gets stuck, how do you free it up to try another pull? Is it the rope being pulled out and won't wind back up or is the recoil binding and won't allow the rope to be pulled out? Does your motor have electric start and if so, does the engine crank over or does it lock up also?
Will the engine turn over easily with the spark plug removed and using the pull starter?
post #9 of 15 Old 01-19-2016, 11:20 AM Thread Starter
Grunt the recoil is fine it won't let me pull the chord out, at least the first pull. That's the first pull of every time i try to start, so let's say that good second pull that goes all the way through if it doesn't start then I am going to get stuck half way on the next first pull. It's just an annoying pain in the ass. Been out snowblowing the last two days so I'm going to watch these videos and see if it helps,
post #10 of 15 Old 01-19-2016, 08:32 PM Thread Starter
Yeah none of this helped, to be honest I have TO much recoil. Like that first half pull i get the machine rips the chord out of my hand and sucks it right back in. Maybe just a brand new rope and recoil? Or can this be a problem inside the engine.
