Augur belt manufactured narrow? – 7/16 instead of 1/2 - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 01-28-2016, 02:51 PM Thread Starter
Have a quick question, I recently ordered a replacement belt for my auger, the belt should measure 31”x1/2”x1/2” which is what I ordered and what is on the product description. The correct belt/part number arrived, but it’s just a bit narrow at 31”x7/16”x7/16”. Will this create any performance issues with the augur and are some belts just manufactured narrow? I would think having the full 1/2" would give just a bit more grip.
The belt is made by Stens, True Blue 248-031 with DuPont Kevlar Cords.
Thanks,
tuc1138 is offline
post #2 of 6 Old 01-28-2016, 04:09 PM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 30
Likes (Received): 43
As long as it don't bottom out on the pulleys, it should not be a problem, but you should try to get the right size belt.
Sid
Sid is online now
post #3 of 6 Old 01-28-2016, 08:01 PM Thread Starter
Thanks Sid. I also have a 3/8 Stens belt for the drive pulley and does measure out at 3/8. I'll find a true 1/2 and keep this as a spare.
CT
tuc1138 is offline
post #4 of 6 Old 01-28-2016, 08:09 PM
Likes (Received): 66
The Code indicates that it is ½" Wide; what is printed on the backside of the belt ?
If it's something different, then you should be able to return it . . . . or exchange it for the correct belt.
Vermont007 is offline
post #5 of 6 Old 01-29-2016, 07:29 AM
Likes (Received): 345
Sid
Agree. If you have a place like Fleet Farm or some other place that deals with blowers or farm equipment, you'll likely find what you're looking for.
HCBPH is online now
post #6 of 6 Old 01-29-2016, 07:38 AM
Likes (Received): 42
Can't see a problem with a belt being off by 1/16 inch in width. That,s 1/32 inch on each edge. It will sit ever so slightly down in the sheave. Most are off by fractions of a inch in length anyway. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
