new height adjustment skids worn out in a week - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 11-28-2010, 01:19 AM Thread Starter
just installed some new hieght adjustment skids and after only one week they are completly worn out. I do snow removal for about 9 properties and this past week we had two blizzards plus I do have 10-15lbs extra wieght in the front. 95 craftman 8p 24". Does this mean I will be having to buy new skids every week? I don't get it I just don't understand how they can only last a week.
Craftsman 8hp is offline
post #2 of 10 Old 11-28-2010, 07:23 AM
Well Im sure its the weight thats doing it. They are steel skids right? One thought is if your doing a lot of blowing, and mounting weight on it, I would rig up a bracket that will hold a skateboard wheel on each side. The nylon they are made of lasts a long time, doesnt scrach pavement, and eaven if the bearing seezes up, you still have a long lasting wear surface.
Ingersoll444 is offline
post #3 of 10 Old 11-28-2010, 09:38 AM
probably a weight issue . i would rig up a "quick on/off" weight bar so you only need it on the selected areas that your blowing off.
trdr is offline
post #4 of 10 Old 11-28-2010, 09:52 AM
Thanks (Received): 238
Likes (Received): 606
post #5 of 10 Old 11-28-2010, 09:59 AM
Originally Posted by bwdbrn1 View Post
Thats just what I was talking about. Not a bad price eather
post #6 of 10 Old 11-28-2010, 10:16 AM
By golly, here's a video of them in action too. Might be just the ticket to your problem Craftsman 8hp.
Raftery Design 1250 - Roller Skid Snow Thrower Skid Shoe (Pair)
post #7 of 10 Old 11-28-2010, 10:34 AM
What I did was I bought a small box of hard weld welding rods, brought them to a friend who has an arc welder, and had him weld a bead of the hardweld on the bottom of the shoes and the scraper blade. That was 8 years ago. I was going thru a pair of shoes every year.
indypower is offline
post #8 of 10 Old 11-28-2010, 02:36 PM Thread Starter
The skid wheel looks neat but I bet that would last as long as any other metal skid which in my case would not be very long. I'm going to have a friend weld some thick metal onto the skid like indypower suggested.
post #9 of 10 Old 01-17-2011, 06:55 PM
I will be ordering a set of the ArmorSkids.
they are thicker, longer, and powder-coated.
Home
Bob is a member of Garage Journal and several members recommended them
"laser cut from 1/4 thick steel plate"
http://www.snowblowerskids.com/
sselander is offline
post #10 of 10 Old 01-14-2012, 06:36 PM
Poly Skid Shoes Wear Better Than Steel
I would recommend poly shoes instead of steel. UHMW polyethylene wears up to 15 times better than steel on concrete and doesn't rust either. I machined some out of solid poly bar for my machine. They can be seen at the following link.
Magnitude Engineering
mecheng10 is offline
