Valve Adjustment On Tecumseh 5hp - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 02-27-2016, 02:36 PM Thread Starter
I checked valve clearances today on my Tecumseh HSSK50 engine. The intake was .013 and exhaust had 0 clearance. I know I need to grind the exhaust valve to get the clearance. Specs for the intake side show .005-.007. Since I am at .013, how can I decrease clearance?
ColoradoDoug is offline
post #2 of 7 Old 02-27-2016, 02:56 PM
Thanks (Received): 173
Likes (Given): 414
Likes (Received): 661
Maybe lap the valve
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
Likes RAYAR liked this post
post #3 of 7 Old 02-27-2016, 03:47 PM
Thanks (Received): 112
Likes (Received): 298
You probably need to have the valve edges ground, then lap it in, or get a new valve, lap it, then grind the stem to get final clearance. Old valve was probably ground too much in the past.
Work fascinates me.
skutflut is offline
post #4 of 7 Old 02-27-2016, 03:54 PM
Blackfin's Avatar
Thanks (Received): 18
Likes (Given): 21
Likes (Received): 40
TBH, I wouldn't touch the intake clearance. Even if it's on the high-side you're not really hurting anything (besides giving up ~0.006" opening which isn't really going to affect power output) and have a bit of margin before valve-seat recession closes the gap down.
I'd be more worried as to why the exhaust gap has closed to zero. Check its valve seat for erosion/recession and its face for wear.
Blackfin is offline
post #5 of 7 Old 02-27-2016, 08:01 PM
Likes (Given): 9
Likes (Received): 30
You might want to double check that you don't just have a tiny piece of carbon stuck under the intake valve.....
bwright1818 is offline
post #6 of 7 Old 02-28-2016, 04:25 PM Thread Starter
I just cleaned all around the valves, no more carbon. I am getting a valve spring compressor, then I will dig deeper.
Likes bad69cat liked this post
post #7 of 7 Old 03-05-2016, 10:33 AM
Likes (Given): 26
Doug,
The valve springs are not very strong and compress easily. I didn't have a compressor when I did mine so I just used a needlenose pliers. Definitely easier with the right tool, but you can do it without one.
York v45 is offline
