Champion or Autolite? - Snowblower Forum : Snow Blower Forums
post #1 of 23 Old 02-28-2016, 02:11 AM Thread Starter
Thanks (Given): 39
Likes (Given): 46
Likes (Received): 6
For general all-around use in small engines - snow blowers, mowers, tractors, etc. - which do you all prefer? This is just between Champion J17LM/J19LMs and Autolite 456/458s please - I have my own opinions about other brands and #s. And before I add my 2 cents, just wanted to see what you guys think. This should be interesting - thanks!
wildbill59 is offline
post #2 of 23 Old 02-28-2016, 02:39 AM
neither. i prefer an ngk br2lm in old flathead engines
post #3 of 23 Old 02-28-2016, 02:58 AM
Yanmar Ronin's Avatar
Thanks (Given): 100
Thanks (Received): 83
Likes (Given): 81
Likes (Received): 404
And I'd rather install a peanut than an Autolite.
Yanmar Ronin is offline
post #4 of 23 Old 02-28-2016, 04:48 AM
Likes (Received): 345
My experience with Autolite plugs is limited to cars and trucks. I don't like them. Additionally I prefer Champions to them or Motorcraft plugs.
HCBPH is online now
post #5 of 23 Old 02-28-2016, 07:45 AM
Thanks (Received): 238
Likes (Received): 608
Only one plug to use IMHO...NGK. One of my local Toro dealers told me they were switching to NGK plugs exclusively because they have encountered too many failures with Champions and I'm going to guess they install a lot more spark plugs than I do.
Likes Kiss4aFrog, detdrbuzzard liked this post
post #6 of 23 Old 02-28-2016, 08:11 AM
Thanks (Given): 589
Likes (Given): 4364
Likes (Received): 1741
I'd go Champion over the Autolite (and NGK over the Champion if you were asking).
post #7 of 23 Old 02-28-2016, 08:45 AM
Thanks (Given): 102
Likes (Given): 273
Bill: NGK
uberT is offline
post #8 of 23 Old 02-28-2016, 09:09 AM
Thanks (Received): 18
Likes (Given): 21
I don't think you'd see a functional difference. You won't notice the engine running any better or worse with either, all else being equal.
I've had a single instance of a Champion snapping during installation, leaving the threaded portion in the head. For that one reason I'm more apt to look elsewhere. But all plugs, even the vaunted NGK can have this happen:
Get the right heat-range, make sure the gap is right and the electrodes are in good shape, use anti-seize and torque the thing right. After that, it won't matter what plug you run. IMO.
Blackfin is offline
post #9 of 23 Old 02-28-2016, 09:21 AM
Likes (Received): 20
I concur, go with NGK. Noticeable running difference in everything from Briggs 4-cycle, Tecumseh 2 and 4-cycles and especially in Chinese OHV 4-cycles.
In car applications I prefer a regular Champion to a regular Autolite, but for Iridium plugs I will take an Autolite over a Champion. I will also use a Autolite Racing plug for supercharged/nitrous apps over anything else for durability.
Personally, In performance-car apps, I really don't like NGK plugs. There is something funky with their designs that don't do well with hot coils/perfomance ignition systems. With stock coil-on-plug or coil-packs the NGKs do really well. And the NGK iridium and platinum designs are really good in those stock applications as well.
Based on what I learned with small-engine stuff here this last year I will only use NGKs in OPE. I am a BIG stickler of picking the right heat-range though (it might not be as critcial as on car engines, but I figure the manufacturers know what they want for a particular design), so to disagree with some here, do a proper cross-reference and do not just throw in "what fits".
DennisP is offline
post #10 of 23 Old 02-28-2016, 09:27 AM
Blackfin, I have NEVER seen that happen on a plug yet. Out of all failure modes I would NOT expect that.
Honestly, I have done hundreds and hundreds of plugs at this point (probably closer to thousands now that I think of it), and I have never seen that. Heck, only twice have I seen pulled threads on a car head (previous owner cross-threading ignorance) and only recently have I had the threads pull on a Briggs L-head engine (and I know the plug was torqued properly all 5 times it was replaced, so I know it is a known Briggs problem).
I would have to imagine that to shear the threaded portion off a plug you would need to torque it into an iron-head, since I can only imagine an aluminum head would pull the threads before that happens. Unless there is a more recent problem with plugs in the past 5-8 years (I have slowed down on car stuff since I bought a house).
DennisP is offline
