PLEASE HELP = Craftsman 536886331 = Clutch Cable - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 03-02-2016, 09:41 PM Thread Starter
Hello. I need guidance. I broke the Clutch Cable that connects to the Auger Drive Lever on my Craftsman 10 Horsepower 29 Inch wide snow blower. It is Model # 536.886331. It is only about 12 inches long. It has a " S " shaped part on one end and a Loop on the other end that attaches to a spring that is connected to the Control Lever up top to engage the auger. I have NO idea how to disconnect the " s " shaped part from the auger drive lever. Please help me.
craftsman1029 is offline
post #2 of 8 Old 03-02-2016, 11:41 PM
Thanks (Received): 112
Likes (Received): 292
That part is called a Z fitting. Disconnect the bottom end of the cable, then you have the slack to lift the cable 90 degrees and slide the z fitting out of the hole in the handle.
Work fascinates me.
skutflut is offline
Likes bad69cat liked this post
post #3 of 8 Old 03-03-2016, 08:41 AM
Likes (Received): 277
Here's a link for parts and descrptions also: CRAFTSMAN SNOW THROWER Parts | Model 536886331 | Sears PartsDirect
I usually take the part numbers and search ebay before buying from Sears though..... much cheaper that way.
post #4 of 8 Old 03-03-2016, 10:02 AM
Thanks (Given): 510
Thanks (Received): 681
Likes (Given): 3844
Likes (Received): 1478
Plus one. For the most part Sears is almost always quite a bit higher.
post #5 of 8 Old 03-04-2016, 10:45 PM Thread Starter
Hello. I am the guy with the Craftsman 536886331 = Clutch Cable. I need to disconnect it from the spring to inside the machine - not the handle.
post #6 of 8 Old 03-05-2016, 08:56 AM
Likes (Received): 16
as a new guy here, try a picture of the problem - looked quickly at parts blow-up and I think there's a threaded connection that ties the cable to "inside" - of course, i could be wrong since I'm looking at a drawing and not the real thing
firedudetl1 is offline
post #7 of 8 Old 03-05-2016, 09:25 AM
td5771's Avatar
Likes (Received): 57
To start you need to remove the belt cover, then you have to tilt the machine on its nose and remove the bottom panel. Take a look and you should see how it is routed. Then we can help from there.
Don't forget to empty the gas first or turn the gas valve off and put plastic under the gas cap.
td5771 is offline
post #8 of 8 Old 03-05-2016, 11:03 AM
Thanks (Given): 510
Likes (Given): 3844
to the forum craftsman1029
If you still need more help just post a photo of where you're having a problem.
