Friction Wheel Bearing help - Craftsman 8hp 25" - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 03-11-2016, 02:23 PM Thread Starter
Thanks (Given): 9
Likes (Received): 15
I have the above blower and have been having trouble with it jumpimg into reverse when put into 2nd gear. I took the bottom off and noticed a lot of play in the friction wheel shaft. I think the wheel was skating on the plate when in 2nd. I also noticed that the bearing flanges (picture attached - not mine) had the raised portion facing out. I think they should be facing in to take up the slack in the shaft. Am I correct? Also, do they go outside the blower shell to seal the hole or inside and are the nuts inside or out? Bought the unit used and the drive never worked right in the lower gears. I expect that if the slop is taken oout of the shaft things would work better. Also, the one on the right of my blower has the bearing inserted opposite to the one illustrated. Are they easy to knock out and reinsert?
Thanks very much in advance.
Name:	85504 Bearing_.jpg
Mid-1980s Craftsman C950-52677-7
8/25 Tecumseh HM80
1983 10/32 Craftsman C459.52252
HMSK110 re-power
Southern New Brunswick near Bay of Fundy
Taurus04 is online now
post #2 of 14 Old 03-11-2016, 08:02 PM
AL-
Thanks (Given): 7
Likes (Received): 29
I have a C950-52678-7 (8hp-28). given to me but was only interested in the engine . I"m now using the parts manual as reference hoping I could help you.
However my friction wheel shaft has a much different set up for bearings. It has a spindle housing and two needle bearings for shaft rotation and a needle bearing sandwiched between two thrust races that keep the friction disc from moving lengthways away from pressure when pushed on by the rubber friction wheel. Parts for mine are no longer available. I'm wondering if the person you got yours from did a make-shift because he could not get parts and is the reason yours works differently.
I could be all wrong about this but I only have one digit different in my model #
AL- is offline
post #3 of 14 Old 03-11-2016, 08:25 PM Thread Starter
Thanks (Given): 9
I have the manual for the blower and the parts seem correct for the unit. The case is stamped for the carriage bolts square slots that hold the bearings in. They are the right assembly. The one I am questioning just looks like it was put together in reverse. The manual show that it is two pieces, but the replacements I see are one piece - bearing and flange as per attachment. I am wondering how hard it is to knock ouot the bearing and flip it to go through the other way.
8/25 Tecumseh HM80
HMSK110 re-power
post #4 of 14 Old 03-12-2016, 03:42 AM
Thanks (Received): 28
Likes (Received): 58
I was looking for a parts breakdown to get a better idea but didn't see one yet.
However I have separated many similar bushings in flanges. If you have a bench vise it is very easy with a block of wood on one side and socket on the other.
No vise, place a piece of wood on the floor and put the bronze bushing side down on the wood, then use a socket big enough to tap the flange down past the bushing so the bushing goes into the socket.
td5771 is offline
Thanks Taurus04 thanked for this post
post #5 of 14 Old 03-12-2016, 06:50 AM Thread Starter
Thanks (Given): 9
Exploded parts diagram
This is the diagram from the manual showing the parts. #s 36 and 37 are the bearing in question.
8/25 Tecumseh HM80
HMSK110 re-power
post #6 of 14 Old 03-12-2016, 06:52 AM Thread Starter
Thanks (Given): 9
Missing Attachment.
Forgot to upload attachment.
Name:	8_25 Craftsman Snowblower-Drivetrain 1a .jpg
8/25 Tecumseh HM80
HMSK110 re-power
post #7 of 14 Old 03-12-2016, 04:38 PM
Thanks (Given): 10
Thanks (Received): 19
Likes (Given): 9
Likes (Received): 59
Question
It looks more like part numbers 37 & 38?
The whole piece is listed as Part #51?
I hate shoveling SNOW!
22" Dual Stage
"Classic" 1963 S-226 Snowbird
22" Dual Stage
Big Ed is offline
post #8 of 14 Old 03-12-2016, 04:44 PM
Thanks (Given): 10
Likes (Given): 9
In your first post the picture shows the one side, what does the other side look like?
It very well could be someone put it in backwards?
Either side is the same part numbers.
22" Dual Stage
22" Dual Stage
Big Ed is offline
post #9 of 14 Old 03-12-2016, 06:02 PM Thread Starter
Thanks (Given): 9
You are correct Big Ed. #51 is the assembly and the parts are 37/38. I do not have a picture of tyhe other side as I got this one off the internet. The bearing has a "collar" on the other side. I really think mine is in the flange backwards. The wheels were seized on when I bought it and I think a lot of the maintenance was done the convenient way for that reason. I know there are a couple of 8/25s on the forum and was hoping someone could tell me if the flange goes inside the blower shell or outside. When I next service the blower, I will change the bearing to match the photo in the first post.
8/25 Tecumseh HM80
HMSK110 re-power
post #10 of 14 Old 03-12-2016, 06:14 PM Thread Starter
Thanks (Given): 9
Here is a photo soon after I bought the snowblower. If you note the black arrows, there is a bearing in each way.
8/25 Tecumseh HM80
HMSK110 re-power
