Predator 212 governor shroud - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 03-18-2016, 02:43 PM Thread Starter
Likes (Received): 14
Today I installed this on my predator to try and keep governor linkage from icing up. I still need a guard on top between the muffler and air box. I will be working on that next.
ID:	84817   Click image for larger version
ID:	84825   Click image for larger version
LB522r is offline
Likes Grunt, Toro-8-2-4, Mike C. liked this post
post #2 of 16 Old 03-18-2016, 06:50 PM
Thanks (Received): 173
Likes (Given): 415
Likes (Received): 664
nice work !
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #3 of 16 Old 03-18-2016, 07:01 PM Thread Starter
The front half is my old license plate.
LB522r is offline
post #4 of 16 Old 03-18-2016, 10:11 PM
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
Nice work! A green machine in more ways than one. I a working on my own shroud and it is a work in progress. I will post pics when complete.
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #5 of 16 Old 03-19-2016, 11:20 AM
Thanks (Given): 14
Likes (Given): 44
Likes (Received): 50
Looks good, I did something similar. Do you have plans to cover the top?
Rob711 is offline
post #6 of 16 Old 03-19-2016, 11:26 AM Thread Starter
I do have plans to cover the top. I built a box that covers the muffler and air box but I may not use it in fear it might get to hot. I may just cover the linkage and leave everything else uncovered
LB522r is offline
post #7 of 16 Old 03-19-2016, 02:59 PM
Thanks (Given): 67
Likes (Given): 115
From some of the prototyping I have been doing I have noticed when I covered the complete top of the muffler some exhaust gas would blow back under the muffler shield and then out the top vents. It did warm the area some but I did not run it enough to get a real good feel for how it would do under a variety of outdoor conditions. What persuaded me to not totally cover the vents was that I did not want a lot of exhaust gas getting under the shroud, leaving soot and ultimately being sucked into the air intake. I am running with out the filter. It seems like having water freeze in the carb is a rare event or possibility.
So far I have found that as long as I keep the linkages free of snow and water they run just fine. Water and slushy snow hitting the gas tank and running onto the linkages has been an issue. I am working on that as well.
Current machines
Ariens 926LE
post #8 of 16 Old 03-19-2016, 03:18 PM
Likes (Received): 7
I live in an area where we can be blowing snow at -30 F or colder. The carburetor intake ideally needs warm air between 70-100 F. The heat radiating from the exterior of the muffler is all you need to warm the area inside the "stove" as we call it. With no air cleaner, I frown upon any exhaust gas going near the carburetor intake. Exhaust equal flame, so any backfire,,, Well that can't be good. I've put out air cleaner fires in vans from backfires. Happens!
So cover up those holes?
Mr Fixit is offline
post #9 of 16 Old 03-19-2016, 10:26 PM
Waterlooboy2hp's Avatar
Likes (Received): 31
Here is what I did and it has worked out very well. This was my prototype and I found , that the hot air intake adjustment was not needed. Construction of the unit, was to complicated to be considered an easy fix. This one is on a 212cc Predator. Found that I could leave the heat flow control wide open and only plug 2 of the 4 original cold air intake holes. The mix of the cold and hot air works well.
I decided to see if I could simplify the unit, with off the shelf parts. I was going to make a 2ed unit, to use on my 346cc Predator powered blower. Noticed that the plastic carb cover on the 346cc is only a single wall, while the 212cc engine has a double wall cover.
Came up with this version. Just a 1" conduit connector and a short piece of 1" conduit pipe. Simple and pretty easy to do. It works on the double wall 212cc engine also, but the location of the hole in the plastic cover is important, to make use of the supports, between the 2 walls. ---- John
This is the one on the 212cc engine with the double wall carb cover.
Inside the carb cover ---
Tube stops just outside the muffler cover.
Used a 1 1/4" hole saw for both holes.
Waterlooboy2hp is offline
Likes YSHSfan, murf liked this post
post #10 of 16 Old 03-20-2016, 11:08 PM
Thanks (Given): 67
Likes (Given): 115
Here is what I have come up with so far. I have left the rear open so far. This way I can monitor what is going on in there. the top cover is Made from galvanized 26 Ga sheet steel. The cover is held on with 3 #10 screws which makes it easy to remove. The side/front governor cover is a .100 thick steel bar with a 90 degree bend. It is a bracket for a wood fence that you can buy in any fine hardware store. I sealed the gas tank to the cover with strips of foam weather stripping. Two layers.
heat does build up but does not seem to be too much.
Hopefully I can give it a field test tomorrow.
Name:	Bottom view (800x600).jpg
ID:	85026   Click image for larger version
Name:	top view (800x600).jpg
ID:	85034   Click image for larger version
Name:	front vew  (800x600).jpg
ID:	85042   Click image for larger version
Name:	side vew (800x600).jpg
ID:	85050   Click image for larger version
Name:	rear view (800x600).jpg
Current machines
Ariens 926LE
Thanks Rob711 thanked for this post
