New Ariens Gas cap won't come off - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 03-21-2016, 06:50 PM Thread Starter
My new Ariens works great but I can't get the gas cap off. It turns about half and inch and stops dead. Thought it might be vapor locked and waited for colder weather again but the same. Any suggestions???
Oops wrong forum meant for this to go in repairs.
HOF44 is offline
post #2 of 11 Old 03-21-2016, 06:54 PM
I think a lot of the new caps are just 1/4 turn and then lift.
post #3 of 11 Old 03-21-2016, 07:00 PM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 269
Yup. Just turn 1/4 then lift. It's not a threaded type of cap. Not very fond of it myself.
GoBlowSnow is offline
Likes uberT liked this post
post #4 of 11 Old 03-21-2016, 07:46 PM Thread Starter
It will only move about 1/2 an inch. But does not lift off. Weird.
HOF44 is offline
post #5 of 11 Old 03-21-2016, 09:25 PM
Thanks (Given): 590
Likes (Given): 4366
Likes (Received): 1742
I don't know about the new caps but I you to "repairs".
post #6 of 11 Old 03-21-2016, 09:53 PM
Thanks (Given): 66
Thanks (Received): 123
Likes (Given): 114
Likes (Received): 157
The gas cap is often a problem due to the strainer fitting below it. Some have removed the strainer altogether after trouble removing and installing the cap.
Have you tried pressing down hard on the cap and turning it. There are a number of detents on the underside of the neck that mesh with 2 protrusions on the cap so when the cap is pressed down it is released from the detents.
Good luck.
Town is offline
post #7 of 11 Old 03-25-2016, 07:23 PM Thread Starter
Finally got it off. Oil filter wrench did the trick, came off easily with that.
HOF44 is offline
post #8 of 11 Old 03-25-2016, 10:17 PM
knu2xs's Avatar
Thanks (Given): 133
Thanks (Received): 126
Likes (Given): 286
Likes (Received): 146
Good to hear!
Can you now put it back on and take it off, by hand??
knu2xs is offline
post #9 of 11 Old 03-26-2016, 08:03 AM
Thanks (Received): 57
Likes (Given): 425
Likes (Received): 139
Glad I'm not the only one that does that
Phil
Ariens 2 foot SHO
1894 is offline
post #10 of 11 Old 03-26-2016, 08:19 AM
wdb
Thanks (Received): 23
Likes (Given): 43
Likes (Received): 69
That was one tight gas cap!
wdb is offline
