Pulley question - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 03-22-2016, 12:21 PM Thread Starter
Kensico's Avatar
Thanks (Given): 24
Likes (Given): 37
Likes (Received): 14
Pulley question
I have an old Hahn 524 , the pulley that drives the auger and wheels is rusted through, I can't find part anywhere Jacks small engines had it listed , I ordered it and got an email saying no longer in stock. It is 8" od with a 3/4" non keyed bore ,it attaches to spindle with a roll pin and it takes a 3/8" v belt. The closest I have found is a cast iron pulley 7-3/4" od ,with a 3/4" keyed bore with set screws to attach to spindle and it takes a 1/2" belt. I guess I could buy a pulley for the engine that is a 1/4" bigger 2-3/4" and a 1/2" belt to go with it(it is 2-1/2" for a 3/8") . My question is will I have problems going from steel to a little heavier cast iron,and changing pulley and belt sizes a little. I think using the set screws instead of roll pin won't be a problem though. Think it'll work? Thanks Kensico
Kensico is offline
post #2 of 16 Old 03-22-2016, 01:16 PM
A lot of people change belts and pulleys around a little bit when putting new engines on blowers. You will probably be alright. You might be better off drilling out the set screw holes and keeping the roll pin though. I would think a pin going all the way through will hold a lot better than a screw.
Thanks Kensico thanked for this post
post #3 of 16 Old 03-22-2016, 03:02 PM Thread Starter
Kensico's Avatar
Thanks (Given): 24
Likes (Given): 37
[QUOTE=Shryp;989946]A lot of people change belts and pulleys around a little bit when putting new engines on blowers. You will probably be alright. You might be better off drilling out the set screw holes and keeping the roll pin though. I would think a pin going all the way through will hold a lot better than a screw.[/QUOTE
Thanks I will drill out it was really hard to get the old roll pin out,lots of penetrating oil and patience.
Kensico is offline
post #4 of 16 Old 03-22-2016, 04:27 PM
Likes (Received): 345
I'll tell you a little story that may give you some ideas.
About 25 years ago I damaged a cast iron pulley on a 100 year old metal lathe. Very odd configuration and impossible to find a replacement. I went to see my folks one time and had it in the car for a long time. Happened to be an old machine shop that worked on alot of farm equipment. I stopped by on a lark to see if he could heat, straighten it and weld it back together.
He said he couldn't because he didn't have a forge but he could make me a new one.
Turned out he had a rack of hubless pulleys and hubs without pulleys. Found the right hub and the right pulley. Pressed them together and got them straight then arc welded them together. Instant correct pulley. It wasn't as pretty as the original cast iron one but it worked and I've been using it ever since without a problem.
He told me he could make up a pulley for any piece of any brand of farm equipment just by mixing and match the right hub to the correct pulley.
Unfortunately the guy died about 10 years ago and the business was ultimately auctioned off. But before he died, I had a couple of additional pulleys for other things made. They worked right up till the time I sold them.
HCBPH is offline
post #5 of 16 Old 03-22-2016, 06:15 PM
Kensico. Let us know how that pulley worked out. Even a picture would be worth seeing. Thank
Onjig is offline
post #6 of 16 Old 03-22-2016, 06:32 PM
Likes (Received): 7
In Canada a store by the name of Princess Auto sells just what you need. You would choose a hub from the list and a correct pulley. The hubs and pulley attach by 3 bolts in the centre. Years ago I built garden shredders, sawdust feeders for smokers from their stock.
It's a supply place for do-it-yourself farmers that modify and improve farm machinery. They do have an online catalogue.
Search results for 'pulleys' | Princess Auto
Mr Fixit is offline
Likes toroused liked this post
post #7 of 16 Old 03-22-2016, 07:22 PM Thread Starter
Kensico's Avatar
Thanks (Given): 24
Likes (Given): 37
I checked out that site very cool I saw an 8" on the first page ,wish there was some place like that closer.
Kensico is offline
post #8 of 16 Old 03-22-2016, 07:23 PM Thread Starter
Kensico's Avatar
Thanks (Given): 24
Likes (Given): 37
Will do, I need to order smaller pulley first
Kensico is offline
post #9 of 16 Old 03-22-2016, 08:15 PM
Likes (Received): 7
Not sure if you chased down the hub centre piece. I see they don't offer the 3 bolt mount anymore. Only weld type. here's the 3/4" hub you're looking for.
Search results for 'hubs' | Princess Auto
Mr Fixit is offline
post #10 of 16 Old 03-22-2016, 08:34 PM Thread Starter
Kensico's Avatar
Thanks (Given): 24
Likes (Given): 37
Thanks, the shipping would be $18 and then I would have to pay someone to weld it so it's to pricey for me now,wish they were closer I see that they also have winter engines which I've never seen in auto stores down here.
Kensico is offline
