8hp Tec.. odd symptom - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 03-23-2016, 08:19 PM Thread Starter
Likes (Received): 10
father in laws machine, so
8HP Tec... nothing out of the ordinary here right.. starts up well.. throttles up and down with a sputter if you move to quickly.. re-starts warm without choke and only prime or only choke just fine..
so heres the weird part.. the primer bulb.. while its running seems to be geting preassurised with gasoline somehow... itl stall itself out at some point by which theres actually a few drops of gas getting squished out of the primer bulb itself... what gives!?!?? i cant think of how the carb could be sending preassure when it should be getting vacuum from the engine to the only vacuum line ( if i may call it that) hooked up to it...
1984 Columbia 10hp-33in
2015 Columbia 420cc 28in 3xHD
Marty013 is offline
post #2 of 7 Old 03-23-2016, 09:54 PM
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3337
Likes (Received): 679
Hello Marty. Try pushing a sewing needle or thin wire through the atmospheric vent hole on the side of the carb. (figure-15) in the link below.
Disassembly, Cleaning and Repair of Tecumseh Series 1 Carb 632107
post #3 of 7 Old 03-23-2016, 10:07 PM Thread Starter
will try.. could this be partially why this engine seems dofficult to get... just right... ? i can get it close enough.. but never just right..
Marty013 is offline
post #4 of 7 Old 03-23-2016, 11:31 PM
Thanks (Given): 275
Likes (Given): 3337
Quite possibly. The pressurized bowl would be forcing more fuel into the main jet and upsetting a consistent metered fuel flow to the engine. Just my opinion.
post #5 of 7 Old 03-24-2016, 08:33 AM
Likes (Received): 280
Also check that the tank cap vents.....
Likes Grunt liked this post
post #6 of 7 Old 03-24-2016, 10:19 PM Thread Starter
bad69 thanks.. but ive tried a different cap and no change
Marty013 is offline
post #7 of 7 Old 03-25-2016, 09:09 AM
Thanks (Received): 35
Likes (Received): 81
+1 on the vent hole on the carb
CarlB is offline
