Electronic Ignition Systems. - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 03-27-2016, 06:52 PM Thread Starter
E350's Avatar
Thanks (Given): 280
Thanks (Received): 62
Likes (Given): 159
Likes (Received): 77
Ok you electronics wizards, I was reading about E-boxes which contain the starter solenoid, stop relay, rpm limiter and coil/ignitor module in jet skis, and it got me to thinking:
Do our snow blowers use Capacitor Discharge Ignition?
https://en.wikipedia.org/wiki/Capaci...harge_ignition
And if so, do the snow blowers without an on-board battery use AC-CDI?
And do the snow blowers with an on-board batter use DC-CDI?
E350 is offline
post #2 of 4 Old 03-28-2016, 05:52 AM
Thanks (Received): 11
Likes (Given): 9
Likes (Received): 30
I will hang my butt out in the wind first and say, "I don't think so." At least, not in the same way as a lot of marine stuff. Tecumsehs have a solid state ignition module, sometimes. (no points) It's my understanding that it works similar to breaker point ignition but uses a transistor, which is controlled by by sensing when the direction of magnetic flux through the coil changes, to take the place of the points. I may be wrong but I didn't think that module will actually store a charge in a big capacitor.....?
bwright1818 is offline
post #3 of 4 Old 03-29-2016, 11:28 AM Thread Starter
E350's Avatar
Thanks (Given): 280
Likes (Given): 159
Great discussion on ELECTRONIC IGNITION SYSTEMS for outdoor power equipment:
ELECTRONIC IGNITION SYSTEMS | smallengineinformation.com
See attached.
HS1132TA is "Transistor magneto" ignition (see attached). Is this the same as a "magneto with switching components" or is it "transistor capacitor"? Both discussed in above article.
My guess based on bwright1818's post above is that it is the former type.
Name:	ELECTRONIC IGNITION SYSTEMS _ smallengineinformation.com_Page_1.jpg
ID:	85681   Click image for larger version
Name:	ELECTRONIC IGNITION SYSTEMS _ smallengineinformation.com_Page_2.jpg
ID:	85689   Click image for larger version
Name:	ELECTRONIC IGNITION SYSTEMS _ smallengineinformation.com_Page_3.jpg
ID:	85697   Click image for larger version
Name:	TECHNICAL & CONSUMER INFORMATION.jpg
E350 is offline
post #4 of 4 Old 03-29-2016, 06:24 PM
Likes (Received): 21
no electrical genius but pretty sure there are no capacitors on electronic ignition snowblower engines.
just a magnet and transistor like bwright said. only place I ever saw capacitors connected to a small engine was on welding machines .
have no clue about jet skis
brickcity is offline
