Storing a Spare Motor - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 04-17-2016, 09:53 PM Thread Starter
Thanks (Given): 7
Likes (Given): 48
Likes (Received): 20
So I have a spare Tecumseh HMSK80 motor that I want to store on the shelf for future use. I am looking for any and all tips and suggestions for what I should be doing to prepare the motor for long-term storage. I'm talking on a timeline that may be a few years long here.
Thanks in advance!
Adam
Flathead Valley, MT
1980 Ariens ST824
1990s Toro CCR1000
The_Geologist is online now
post #2 of 9 Old 04-17-2016, 10:41 PM
put oil in the cylinder and run it out of gas/drain the gas. thats all i would do. dont wrap it in anything or it will trap in moisture and possibly rust the sheet metal
Thanks The_Geologist thanked for this post
post #3 of 9 Old 04-18-2016, 08:05 AM
Thanks (Received): 238
Likes (Received): 608
Ditto to that.
Likes The_Geologist liked this post
post #4 of 9 Old 04-18-2016, 11:51 AM
Likes (Received): 280
Amen.... nice to have a spare handy too!
post #5 of 9 Old 04-18-2016, 05:48 PM
AL-
Thanks (Given): 7
Likes (Received): 29
I 'm working on one to store also. When you take the plug out and with a light you can look in and see the piston when it comes up to TDC if you rotate the crankshaft. I 'm thinking of putting oil in the cylinder when the piston goes down a bit and then keep rotating it thinking the oil will coat everything.
AL- is offline
post #6 of 9 Old 04-18-2016, 10:32 PM
Thanks (Received): 48
Put a teaspoon of oil down the spark plug hole and crank the engine over a couple of times. Drain all the gas out of it, spray the engine, especially the sheetmetal with WD40.
94EG8 is offline
post #7 of 9 Old 04-18-2016, 10:44 PM Thread Starter
Thanks (Given): 7
Likes (Given): 48
Thanks for all the replies! They are very appreciated!
Adam
Flathead Valley, MT
1980 Ariens ST824
1990s Toro CCR1000
post #8 of 9 Old 04-19-2016, 07:46 AM
Thanks (Given): 7
Likes (Given): 29
Likes (Received): 22
They sell fogging oil that will mist into the cylinder and keep it protected. I put the piston all the way down then fog the heck out of it.
KennyW in CT is offline
post #9 of 9 Old 04-19-2016, 12:06 PM
Likes (Received): 345
Pretty much the same as everyone else with a difference or 2. I spray WD40 into the cylinder and run the piston up and down a few times. I make sure the piston is as close to TDC as possible and both valves are closed then put the plug back in. Clean off the outside and lightly oil it.
Done.
HCBPH is offline
