Snowblower sound - normal? - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 07-21-2016, 04:14 PM Thread Starter
Hello, I have a new 7 day old Briggs stratton 205cc single stage snow blower. Its my first.
Again its brand new (summer here now) and I just put it together to make sure its working instead of finding out in December....
Anyhoo, whenever I pull the lever to start the augor(to get the thing turning) it makes a noise. Starting it up is fine, its just when I pull the lever to engaged.
I made a video, and after watching it, it doesn't appear loud. However in person it seems loud, and sounds like a quick,sharp metal scrape,but goes away in an instant and doesn't return while holding in or releasing it. It only happens when its at a standstil, and I pull the lever to engage it.
Is this normal? A friend of mine has a poulan pro, 208cc single, and when he pulls the lever is nice and smooth, zero noise during that transition
Please advise, thanks
EDIT: im unable to post a link to my youtube video since im new.Im sure that would help to get an idea of what im talking about. Guess I have to post a few times,then I can come back and post the youtube link
MDsnowBlower is offline
post #2 of 12 Old 07-21-2016, 05:31 PM
Thanks (Given): 72
Thanks (Received): 398
Likes (Given): 183
Likes (Received): 931
MD, email me the link, sscotsman at yahoo dot com, and I will post it in this thread for you.
post #3 of 12 Old 07-21-2016, 06:36 PM
The sound is probably just the belt. When belts are brand new they are really tacky so when you are engaging the auger the auger is at 0 rpm and the engine is at 3600 rpm. The belt slips a little with the sudden jolt and causes a sound like squealing tires.
post #4 of 12 Old 07-21-2016, 08:17 PM
Thanks (Given): 72
Likes (Given): 183
Here is MD's video:
post #5 of 12 Old 07-21-2016, 10:45 PM Thread Starter
Ah okay, thats does sound about right. Like I said my first snowblower and I got worried because my buddy got a new one couple weeks ago too and his didn't do it at all (different maker/brand tho)
Here is MD's video:
Thank you for helping me out
post #6 of 12 Old 07-22-2016, 02:10 PM
Thanks (Received): 38
Likes (Received): 63
sounds like the belt to me too! nice combination of metal teeth and rubber paddles on the auger, seems like good idea.
stromr is offline
post #7 of 12 Old 07-23-2016, 01:09 AM
Thanks (Received): 143
Likes (Received): 297
Is it a toothed belt?
post #8 of 12 Old 07-24-2016, 07:52 PM
Likes (Received): 303
Like Shryp said, you're going from zero to ~3600 rpm somewhat instantly, there's gonna be some noise. Keep in mind on a SS you are applying all the torque from the belt on one side. 2 stagers apply the torque to the middle of the machine, through a belt and secondly through a set of gears and usually "screech" on engagement to start the process. Could be your friend's (assuming also a SS) has a more sound absorbing housing or different bearings? That engine of yours sounds nice to me, doesn't have a hint of bog on engagement. Wish you good service from her this winter
post #9 of 12 Old 07-24-2016, 09:11 PM
Being a single stage I bet the rubber of the augers is rubbing on the housing slightly too. With a single state the tighter the fit the better it throws.
post #10 of 12 Old 07-24-2016, 09:17 PM Thread Starter
thanks for the kind words
my friends has a Poulan pro 208cc single stage,with the sequahana(spell check) engine in it I believe.
