Ariens Auger screw - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 07-28-2016, 05:10 PM Thread Starter
Ariens Auger screw
Hi all,
I'am in the middle of installing a new auger control on my Ariens model number 910002 and I'am having an issue removing the small hex screw to get the bolt so I can screw it on properly.
Any advice will help.
Thanks!
Dustin
Name:	ariens screw.jpg
dhoyt714 is offline
post #2 of 15 Old 07-28-2016, 05:35 PM
Roll Pin on your Worm Gear (Shaft)
Hi Dustin,
That should be a roll pin, not a hex screw there.
I've placed the bracket in a vice and carefully punched that roll pin out with a punch that is bigger than the outside diameter of the roll pin but smaller than the inside diameter of the hole it rests in.
I've done it many times. Maybe put some penetrating oil on the roll pin and let it sit for a while first.
1969 Ariens Model No. 10962 Serial No. 000971 with H70-130067 and RATO 212cc OHV Engines
1973 Ariens Model No. 910006 Serial No. 009643 with H60-75362J Engine
Zac5 is offline
post #3 of 15 Old 07-28-2016, 07:14 PM
Likes (Received): 483
Originally Posted by Zac5 View Post
Hi Dustin,
I agree, the ones I've dealt with have had a roll pin there.
I think you are a little off there...... it should read
"bigger than the inside diameter of the roll pin but smaller than the diameter of the hole it rests in."
post #4 of 15 Old 07-28-2016, 08:42 PM
Yes, you are correct.
I was trying to multi-task too much there just finishing up marking the Final Math Exams for my Grade 10 students who needed to re-take their Grade 10 Academic course credit in Summer School here in Hamilton, ON
Zac5 is offline
post #5 of 15 Old 07-30-2016, 10:22 AM Thread Starter
Thanks for the replies. Ordered a punch set, should be here today and I will give it a shot.
The other problem I had was the other Auger shaft, the one that I'am swapping the gears off of someone had already tried to drill the pin out. Is this a big problem or will the pin still come out?
dhoyt714 is offline
post #6 of 15 Old 07-30-2016, 11:01 AM
They also sell inexpensive roll pin punch sets.
The fact that someone started drilling it out means that it is probably seized but I would still try to push it out with a punch (use a lot of penetrating spray if you have), in the worse case scenario you will have to finish drilling it out.
post #7 of 15 Old 07-30-2016, 05:08 PM
I have some cheap punches from Harbor Freight that work fine. I would start with a punch quite a bit bigger than the pin or even just the hammer if you can. Once you push the pin flush to the shaft, then start with the small one that will fit through the shaft. Also, be sure to set the gear down on a vice or something so you get a few good solid hits on it.
post #8 of 15 Old 08-04-2016, 03:14 PM Thread Starter
So I have tried punching the pin and drilling it out with no luck. I think its time to find another handle....
dhoyt714 is offline
post #9 of 15 Old 08-07-2016, 06:14 PM Thread Starter
Thanks for all the help. I was able to get the auger screw out and on the blower this weekend. Now on the some carb issues.
dhoyt714 is offline
post #10 of 15 Old 08-08-2016, 08:55 PM
