New gasket or can I just use permatex? - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 08-16-2016, 10:28 AM Thread Starter
pwm
pwm's Avatar
I'm cleaning and rebuilding the carb on my Tecumseh 10hp HM-100 and I have a question. The intake pipe gasket broke in pieces when I took the carb off. Half is on the motor and half on the pipe.
1). When I re-install the carb do I need to replace the gasket (Tecumseh PN27915A) of can I just use some Permatex Gasket Maker?
2). If I get a new gasket do I install it dry or do I use some type of gasket cement with it?
Thanks in advance.
pwm is offline
post #2 of 8 Old 08-16-2016, 12:42 PM
Thanks (Received): 379
Likes (Received): 1377
IF you get a new gasket install it dry no blue,orange or black glue. I would not use anything other than a new gasket in the first place.
post #3 of 8 Old 08-16-2016, 02:01 PM Thread Starter
pwm
pwm's Avatar
Thanks for the reply.
pwm is offline
post #4 of 8 Old 08-16-2016, 02:27 PM
Permatex would work, it will just make it more difficult to remove and clean next time.
post #5 of 8 Old 08-16-2016, 03:17 PM
Thanks (Received): 14
Likes (Received): 65
If the original gasket is no longer available as a repair part, you can also buy a blank sheet of gasket material and then cut out your own with an X-acto knife.
guyl is offline
post #6 of 8 Old 08-16-2016, 04:41 PM Thread Starter
pwm
pwm's Avatar
I bought a gasket today at a parts supply store here in Winnipeg, along with the needle seat that was missing from the kit I got online.
Thanks for the help.
pwm is offline
post #7 of 8 Old 08-16-2016, 05:06 PM
stromr's Avatar
Thanks (Received): 38
Likes (Received): 63
if you lightly coat a gasket with Never Seize it will come right off next time
stromr is offline
post #8 of 8 Old 08-16-2016, 05:19 PM
Likes (Received): 303
If you want the least amount of problems with a Tec carb, replace all the gaskets/o-rings and start new. Been there done that. They are all cheap insurance so you start from a base line.
