Help Me Fix a Local Church's 1960's Wheel Horse - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 09-26-2016, 07:55 PM Thread Starter
A Local Church has reached out to me to get their snow blower in operating order. They said it was an older model...I had no idea it was this old! I did check out some YouTube videos and it seems like a stellar blower. I even plan on installing an impeller kit for them.
Anyhow...I went there and picked it up. Brought it home and got it started on starting fluid...quick test to make sure the engine was a good one.
I took the carb apart and bowl gasket crumbled in my hands. I went to a local repair shop and they wanted just as much for a gasket compared to a replacement carb. So I ordered a new carb...finally Almost 2 weeks it arrived from China. I installed the new carb and it fired up. Sounded like it was reving to high but machine was able to go forward and reverse in high and low on its own. Auger spun great. This was about maybe 2-3 mins and then it just died...
Carb is puking out fuel as it runs and it won't run right...
Here is a video of it running. I hope I don't offend anyone by not trying to save the OE Carb. I am doing this on my time and dime. I have had great success with Chinese carbs...after today I have the OE carb soaking in the parts washer. I will shake it in the AM before work...shake after and blow it out. I will reinstall it with the Gasket from the Chinese carb.
The motor was loose...I don't know why...I have since corrected that since this video. Please help
Foreverfalcon40 is offline
post #2 of 12 Old 09-26-2016, 07:58 PM Thread Starter
How do I post this video? I have it in my photobucket
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid270.photobucket.co m%2Falbums%2Fjj92%2Fforeverfalcon40%2Fsnowblowers% 2F8DE0CA7A-D4C8-4AF8-B2A6-A8EA350D536B_zpsjvebdnlr.mp4">
post #3 of 12 Old 09-26-2016, 08:00 PM Thread Starter
Here is a direct link...according to photobucket...
http://s270.photobucket.com/user/for...bdnlr.mp4.htmL
If there is still an issue feel free to text me 631-707-0797. I can send it via text or through an email
post #4 of 12 Old 09-26-2016, 08:48 PM
Thanks (Received): 38
Likes (Received): 63
I'm on a tractor forum also. Awhile back one of our very skilled members had the same problem with a tractor engine, he tossed the old carb, put on a new clone carb and engine ran like doo-doo. Disassembled the Chinese carb to find it was assembled wrong at factory. Think there were a couple of passages clogged and a jet squashed when they pressed it into a hole. He actually bought a new jet for it and cleaned it up and it ran great.
stromr is offline
post #5 of 12 Old 09-26-2016, 09:14 PM Thread Starter
Thank you! I was thinking that the carb was defective as well...hence the reason why it is soaking in the parts washer. Hopefully weather permitting I can take it out...blow some compressed air into it and use the Chinese carb float bowl gasket on the OE tecumsah.
post #6 of 12 Old 09-27-2016, 11:49 AM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
nice machine!
besides the carb needing TLC, that puppy may be due for a valve job. I wonder if the intake isn't closing fully.
this is what I'm blabbing about:
('87 Toro 38150 826)
post #7 of 12 Old 09-27-2016, 07:35 PM Thread Starter
Thank you for your response. I hope that is not the cast. My plan was also to pull the head and decarbonize.
Thank you...today it was raining which kept me from looking at it again.
post #8 of 12 Old 09-27-2016, 08:08 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 416
Likes (Received): 664
any chance that crud in the tank caused the float needle not to seat ?
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #9 of 12 Old 09-28-2016, 06:44 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
I'm thinking the same thing. I can't see how the fact fuel vapor is being blown out the intake could be the carb's fault. The only other explanation I can think of is someone had the motor apart and when they put it together, they timed the camshaft wrong.
ELaw is offline
post #10 of 12 Old 09-28-2016, 10:12 PM Thread Starter
When I got it the motor was loose...I hope not!
What I don't understand is how it ran fine (reved) real high and now nothing.
Still another day of rain here!
